Routing over switchport but within VLAN/VRF
Steve Prescott
I currently have the topology as per the diagram below on the ‘Internal’ side.
There is OSPF/BGP between the two cores.
VTP is used to ensure all the necessary VLANs are propagated to the edge switches.
I now have the requirement to connect one of the edge switchports to an external link so that clients on the external side of the link (192.168.118.0/24) can access a web server connected to CORE-01 as shown (10.122.10.2).
The question is how do I achieve this?  I obviously need the route adding into the VLAN5 VRF, but where do I point it to and how do I point it down g1/0/19 on the edge switch? How will traffic coming into g1/0/19 on the edge switch know to be in VLAN 5 ?
I know I need to add access-lists somewhere too.
Any advice would be very warmly welcomed.
18 Replies 18
Hi Jon,
Yes that makes much more sense thanks.
I beleive the config will look something like this then....(I think I need two routes on the edge switch as shown).
EDGE
Ip routing
Int gn/n/n
No switchport
Ip address 10.122.50.1 255.255.255.252                      (10.122.50.2/30 at other[external] end)
Ip access-group 101 in
Ip access-group 102 out
Access-list 101 permit tcp 192.168.118.0 0.255.255.255 10.122.10.2 eq 443
Access-list 101 deny ip any any
Access-list 101 deny esp any any
Access-list 102 permit tcp 10.122.10.2 eq 443 192.168.118.0 0.255.255.255
Access-list 102 deny ip any any
Access-list 102 deny esp any any
Int vlan51
Desc For routing between core-edge
Ip addr 10.122.51.1 255.255.255.248
ip route 10.122.10.2 255.255.255.255 10.122.51.6   (hsrp addr on cores)
ip route 192.168.118.0 255.255.255.0 10.122.50.1   (or should this be .2?)
CORE-1
Vlan 51 name “For routing between core-edge”
Int vlan51
Ip addr 10.122.51.2 255.255.255.248
Ip vrf forwarding VLAN5
standby 51 ip 10.122.51.6
standby 51 priority 120
standby 51 preempt
ip route vrf VLAN5 192.168.118.0 0.0.0.255 10.122.51.1
CORE-2
Int vlan51
Ip addr 10.122.51.3 255.255.255.248
standby 51 preempt
Do you concur?
Steve
Yes you do need two routes on edge switch, one for the web server and one for the client. Looks good ,  just a few points -
1) you acls need to include the "host" keyword and the wildcard masks are wrong ie. -
access-list 101 permit tcp 192.168.118.0 0.0.0.255 host 10.122.10.2 eq 443
access-list 101 deny ip any any
access-list 101 deny esp any any
line 2 there is an implicit deny at the end of any acl so you don't need to have an entry unless you want to see how many hits there are.
line 3 - not sure what this is for ?
the above comments also apply to acl 102
2) your routes -
it should be 10.122.50.2
also note your VRF routes are using the wrong masks ie. they should be -
ip route vrf VLAN5 192.168.118.0 255.255.255.0 10.122.51.1
Jon
Brilliant. Thanks very much Jon.
Ignore my line three, been faffing about with firewalls and permitting GRE tunnels.
Your input has been invaluable, and now that I've done it I can see the logic behind it.
Thanks again.
Steve
No problem.
Would be interested to hear how it all goes when you get round to implementing it.
Jon
