Routing. What am I missing???
Michael Durham
Level 4
Level 4
I can ping from Durham's PC to Sommer's PC just fine.
I can ping the Inernet from Server Switch (4.2.2.2) just fine
But I cannot ping the Interent from Office Switch or Durham's PC.  What am I doing worng?
OFFICE SWITCH
version 12.2
ip subnet-zero
ip routing
no ip domain-lookup
ip domain-name mtd.home
interface FastEthernet0/21
description Switch - Server_Switch 192.168.100.101 port fa0/1, Access Point - South_AP 192.168.100.105 port Ethernet 0, Servers
switchport trunk native vlan 100
switchport trunk allowed vlan 69,100,115,125,200
switchport mode trunk
spanning-tree portfast
interface FastEthernet0/24
description Workstation - Sixcore 192.168.69.150
switchport access vlan 69
switchport mode access
switchport nonegotiate
switchport port-security violation protect
switchport port-security mac-address sticky
interface Vlan69
ip address 192.168.69.2 255.255.255.0
ip helper-address 192.168.69.1
no ip route-cache cef
no ip route-cache
router eigrp 1577
no auto-summary
network 192.168.10.0 0.0.0.3
network 192.168.69.0
network 192.168.70.0 0.0.0.3
network 192.168.100.102 0.0.0.0
network 192.168.100.0
network 192.168.200.0
ip classless
ip route 0.0.0.0 0.0.0.0 10.0.0.254
ip route 10.115.0.0 255.255.255.0 192.168.100.101
ip http server
end
SERVER SWITCH
Current configuration : 9278 bytes
! Last configuration change at 16:28:07 Eastern Sun Jan 6 2013 by mdurham
! NVRAM config last updated at 17:23:11 Eastern Wed Jan 2 2013 by mdurham
version 12.2
ip subnet-zero
ip routing
no ip domain-lookup
interface FastEthernet0/1
description BLUE - Switch - Office_Switch 192.168.100.102 port fa0/21
switchport trunk allowed vlan 1,69,100,115,125,200
interface FastEthernet0/7
no switchport
ip address 10.0.0.254 255.255.255.0
interface Vlan69
description - User Vlan
ip address 192.168.69.1 255.255.255.0
ip helper-address 172.16.2.2
no ip route-cache
router eigrp 1577
no auto-summary
network 10.0.0.0 0.0.0.255
network 172.16.2.0 0.0.0.3
network 192.168.50.0 0.0.0.7
network 192.168.125.0 0.0.0.7
ip default-gateway 192.168.100.102
ip classless
ip route 0.0.0.0 0.0.0.0 10.0.0.1
ip route 10.115.0.0 255.255.255.0 10.115.0.1
ip http server
end
Any thoughts??
Michael
39 Replies 39
kcnajaf
Level 7
Level 7
Hi Michael,
Did you try tracert and check where it is failing? Please provide the output of tracert 4.2.2.2 from working and non working switches?
Najaf
Richard Burts
Michael
Based on what you have supplied so far I would guess that the connection to the Internet is doing address translation for 10.0.0.0 but is not doing address translation for 192.168.69.0.
Can you provide some information about how this network connects to the Internet and about how address translation is configured there?
Rick
Rick
Office Switch traceroute to 4.2.2.2
Tracing the route to 4.2.2.2
  1 192.168.69.1 4 msec 4 msec 4 msec
  2  *  *  *
  3  *  *  *
  4  *  *  *
  5  *  *  *
Server Switch traceroute to 4.2.2.2
  1 10.0.0.1 4 msec 4 msec 8 msec
  2 192.168.0.1 8 msec 8 msec 4 msec
  3 192.168.43.1 8 msec 12 msec 8 msec
  4 66.174.39.17 48 msec 40 msec 40 msec
  5 69.83.36.33 44 msec 52 msec 44 msec
  6  *  *  *
  7 69.83.33.13 60 msec 44 msec 56 msec
  8 4.59.90.21 52 msec 44 msec 64 msec
  9  *  *  *
10  *  *  *
11 4.69.150.77 200 msec 68 msec 68 msec
12 4.2.2.2 72 msec 72 msec 72 msec
Ricahrd, I all that I know about the connection to the Internet is that my neighbor has Verizon 4G unlimited data (as do I) and he connects to a router via a game dongle.  That router is on a 192.168.0.0 network.  A second router is connected to that which is hwere the 10.0.0.0 network come in.  I DO have his permission to connect to his network.
In fact, what our long term goal is for both of us to share our Internet connections when we a re both home.  If one of us leaves and takes our phones with us, our come networks will still have Interent via the other person's data.  This way should he/I need access to our home network we can still get there.
You may be asking WHY?  Because there is no cable of DSL service herer.
I plan on giving hime a Cisco 3550 layer 3 switch to replace his main router once I figure everything out.  But first I need to get out his network to the Internet.  Once that is done, I will need to figure a way that I can get out both networks at the same time.
Michael
The additional explanation is helpful, but not conclusive. It certainly suggests to me that his router is doing address translation for his network and not for your network. That would produce the symptoms that you suggest. Can you ask him to check on whether his router connection to the Internet would translate your addresses?
Rick
Rick
HI Michael,
Hmmmm...So the traffic get dropped at the first hope itself. Could you provide the output of "show ip route" from both switches.
Also what is the configuration looking like on 10.0.0.1?
Hope 192.168.0.1 is your internet router..
Najaf
Server Switch show IP route
Gateway of last resort is 10.0.0.1 to network 0.0.0.0
     192.168.10.0/30 is subnetted, 1 subnets
D       192.168.10.0 [90/3072] via 192.168.69.2, 4d02h, Vlan69
     192.168.125.0/29 is subnetted, 1 subnets
C       192.168.125.0 is directly connected, Vlan125
     172.16.0.0/30 is subnetted, 1 subnets
C       172.16.2.0 is directly connected, FastEthernet0/19
C    192.168.200.0/24 is directly connected, Vlan200
     10.0.0.0/24 is subnetted, 2 subnets
C       10.0.0.0 is directly connected, FastEthernet0/7
C       10.115.0.0 is directly connected, Vlan115
     192.168.50.0/29 is subnetted, 1 subnets
C       192.168.50.0 is directly connected, Vlan50
C    192.168.69.0/24 is directly connected, Vlan69
     192.168.70.0/30 is subnetted, 1 subnets
D       192.168.70.0 [90/28416] via 192.168.69.2, 4d02h, Vlan69
     192.168.100.0/24 is variably subnetted, 4 subnets, 2 masks
C       192.168.100.0/24 is directly connected, Vlan100
D       192.168.100.106/32 [90/156416] via 192.168.69.2, 4d02h, Vlan69
D       192.168.100.102/32 [90/130816] via 192.168.69.2, 4d02h, Vlan69
D       192.168.100.103/32 [90/156160] via 172.16.2.2, 2d01h, FastEthernet0/19
S*   0.0.0.0/0 [1/0] via 10.0.0.1
Office Switch show IP route
C       192.168.10.0 is directly connected, Vlan1000
D       192.168.125.0 [90/3072] via 192.168.69.1, 4d02h, Vlan69
D       172.16.2.0 [90/28416] via 192.168.69.1, 2d01h, Vlan69
D    192.168.200.0/24 [90/3072] via 192.168.69.1, 4d02h, Vlan69
D       10.0.0.0 [90/28416] via 192.168.69.1, 03:06:52, Vlan69
S       10.115.0.0 [1/0] via 192.168.100.101
D       192.168.50.0 [90/3072] via 192.168.69.1, 4d02h, Vlan69
C       192.168.70.0 is directly connected, FastEthernet0/23
D       192.168.100.0/24 [90/3072] via 192.168.69.1, 03:07:06, Vlan69
           [90/156160] via 192.168.70.2, 4d02h, FastEthernet0/23
C       192.168.100.102/32 is directly connected, Loopback1
D       192.168.100.103/32 [90/156416] via 192.168.69.1, 2d01h, Vlan69
Yes 192.168.0.1 is my Internet router (neighbors that is)
I do not have access to the config of 10.0.0.1.  It is just a Netgear router.
Your initial running configuration for Office Switch is showing
But the show ip route of same switch shows
Any idea why is this showing like this?
Najaf
Richard,
Are you saying that since his router (192.168.0.1) is not providing me an IP it does not know the return path to my 192.168.69.0 network?
When I connect a laptop directly to the Wireless Bridge, I can get to the Internet.  His 10.0.0.0 router does hav eDHCP set up on it.  I did provide the laptop an IP address outside of the DHCP scope (on the same subnet) and it worked fine too.
Both of his routers are low end comapired to Cisco. The 192.168.0.1 router is a CradlePoint.
Najaf,
My bad.  I keep changinghte 0.0.0.0 route so that I can have Internet and communicate here via MY Verizon 4G netowrk.  When I set it back to run the tests you requested, I entered ip route 0.0.0.0 0.0.0.0 10.0.0.1    I can change it back to 10.0.0.254 if you like.
Hi Michael,
Yes please. Please change to 10.0.0.254 and provide the tracert output to 4.2.2.2 from Office switch.
Najaf
Gateway of last resort is 10.0.0.254 to network 0.0.0.0
D       192.168.125.0 [90/3072] via 192.168.69.1, 4d03h, Vlan69
D       172.16.2.0 [90/28416] via 192.168.69.1, 2d02h, Vlan69
D    192.168.200.0/24 [90/3072] via 192.168.69.1, 4d03h, Vlan69
D       10.0.0.0 [90/28416] via 192.168.69.1, 03:36:07, Vlan69
D       192.168.50.0 [90/3072] via 192.168.69.1, 4d03h, Vlan69
D       192.168.100.0/24 [90/3072] via 192.168.69.1, 03:36:21, Vlan69
           [90/156160] via 192.168.70.2, 4d03h, FastEthernet0/23
D       192.168.100.103/32 [90/156416] via 192.168.69.1, 2d02h, Vlan69
S*   0.0.0.0/0 [1/0] via 10.0.0.254
Office_Switch#sh run | i ip route
no ip route-cache
no ip route-cache
no ip route-cache
Office_Switch#
Office_Switch#
Office_Switch#traceroute 4.2.2.2
  2  *  *  *
  3  *  *  *
  4  *  *  *
  5  *  *
My Final Project it to be able to sit at my PC, 192.168.69.150, and when I surf the Interent I want my Interenet access to use both my Internet and my neighbor's Internet connections at the same time.  My neighbor will also have access to both Interenet connections.  We will both be using C3550 layer 3 switches once I can get dual access working.
You have your next hope configured as 10.0.0.254 and i can see this IP address is assigned to an Fas 0/7. Where is the physical link connected from Fas 0/7 going to?
no switchport
Najaf
