RPVST+ / MST
rherve
Actualy I have a customer to use a lot of vlan in his network (140).
Let me explaine the problem:
On 2960 catalyst switches, it can have a maximum of 255 vlan in the vlan database (OK) but only 128 spanning-tree instance (NOK)
When i use more than 128 vlans, the vlans pass to (no spanning-tree vlan xxx) in the configuration.
When I use MST is there the same limitation ? If someone has the response
THanks per advance
Hervé
Reza Sharifi
You can use MSTP to group you vlans together.
If the number of VLANs on the switch exceeds the  number of supported spanning-tree instances, we recommend that you  configure the IEEE 802.1s Multiple STP (MSTP) on your switch to map  multiple VLANs to a single spanning-tree instance. For more information  about MSTP, see
"Configuring MSTP."
Here is the config gude:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_25_fx/configuration/guide/swvlan.html
Reza Sharifi
"Configuring MSTP."
