RSPAN on 2960
abatuyeva
Hello!
I try to configure RSPAN on 2960 switch. But nothing sends to the destination switch. When I try to do the same in 2950 everything works fine. Here is the configuration of the 2960:
CUS_48ports_2#sh run vl 100
Current configuration:
vlan 100
name Test
remote-span
end
CUS_48ports_2#sh monitor
Session 1
Type : Remote Source Session
Source Ports :
Both : Fa0/24
Dest RSPAN VLAN : 100
However during configuration of RSPAN I get a message from the switch about reflector-port:
CUS_48ports_2(config)#mon ses 1 d rem vl 100
%Note: ingoring the reflector port configuration
I checked the 100 VLAN on both switches: it presents on the trunk, and it's configured on the destination switch:
CUS-48ports#sh run vl 100
Building configuration...
vlan 100
name Test
remote-span
end
CUS-48ports#sh mon
Session 1
Type : Remote Destination Session
Source RSPAN VLAN : 100
Destination Ports : Fa0/31
Encapsulation : Native
Ingress: Disabled
Could you advice something to solve the issue?
pgasparovic
It happens that even in 2020 this may be issue for similar platform 2970, while I just need to run RSPAN by an accident .
Per documentation found reflector config isnot needed, nor is present in the CLI - it's just broken
