Running a 'Stacked' Switch as Standalone
Rygo
Hello. I have a 9200L switch that was previously part of a stack that I removed the configuration from but it still seems to think it is part of a stack and I don't know how to remove.
I ran the command no switch provision to remove the other stack member from the configuration then I ran the stack 2 renumber 1 command. After reloading the switch I see that only 1 switch is detected (screenshot attached) but when I reload after that I get a message about the whole stack reloading (screenshot attached). I have removed the stacking modules from the switch as well.
How can I get this reference to the stack removed? Also, if I left it as is, will it cause problems when it runs as a standalone switch?
