Running HSRP on the same 3750 stack ...
I have a 3750 stack and want to confirm if I can run HSRP on the stack to two different ASR routers for redundancy purposes ?
It looks like the below :-
   |     SW1          SW2  |
   |       3750 Stack        |
    |    P     |   |    S      |
    |  ASR1 |   |  ASR2  |
    | ______|   |_______|
Cheers,
- SN -
Giuseppe Larosa
Hello Sanjay,
you don't need HSRP in this setup the switch stack provides L3 redundancy in its own way, in other words the SVI interface is defined on the stack master and if the master fails another switch is promoted master.
HSRP would provide consistency at MAC address layer, but also this can be achieved if you enable stack MAC address persistency.
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_58_se/configuration/guide/swstack.html#wp1206500
with MAC address persistency the new master will use the same MAC address used by previous master as HSRP would do.
Hope to help
Giuseppe
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained  within this  posting without consideration and with the reader's  understanding that  there's no implied or expressed suitability or  fitness for any purpose.  Information provided is for informational  purposes only and should not  be construed as rendering professional  advice of any kind. Usage of  this posting's information is solely at  reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Yes, 3750 stacks support HSRP.  If you intend the 3750 stack and the ASRs to be gateways for the same subnet, this would be a method to accomplish this.
