Scheduling backup of running-config on TFTP/FTP
mzsaad123
Is there a way to schedule automated backup on a TFTP or FTP server from cisco IOS?
Didn't got a change to go through the details.
Please check the vedio tutorial below for the procedure to configure the achieve command and enable auto backup whenever a change is made -
http://www.blindhog.net/cisco-automatic-configuration-backup/
Apologize if this is a repeatative info.
-> Sushil
12 Replies 12
michael.leblanc
Level 4
Level 4
You can use a product such as Kiwi CatTools to schedule configuration backups, if that helps.
http://www.kiwisyslog.com/kiwi-cattools-overview/
jcoke
Level 3
Level 3
Ivan Pepelnjak wrote an excellent article on using the IOS configuration archive for automated config backups:
http://www.nil.com/ipcorner/RouterConfigArch/
mzsaad123
Here is what I found. Its a feature of cisco ios.
example:
Router(config)# kron policy-list Backup
Router(config-kron-policy)# show run | redirect tftp://10.1.1.1/test.cfg
Router(config-kron-policy)# exit
Router(config)# kron occurrence Backup at 23:00 Sun recurring
Router(config-kron-occurrence)# policy-list Backup
Did you read the article I posted? The IOS config archive feature is so much more robust than redirecting the output of a "sh runn."
hi,
the command path will not save the configs on the tftp server
That's incorrect. The archive feature's path command supports any IOS-supported file system ftp, tftp, http, etc.
http://www.cisco.com/en/US/docs/ios/fundamentals/configuration/guide/cf_config-rollback_ps6441_TSD_Products_Configuration_Guide_Chapter.html#wp1100253
Sorry but i tried it and it did work.
Router(config)#archive
Router(config-archive)#path
Router(config-archive)#path ?
ftp: Write archive on ftp: file system
http: Write archive on http: file system
pram: Write archive on pram: file system
rcp: Write archive on rcp: file system
tftp: Write archive on tftp: file system
below is the link which will help more.
http://blogs.techrepublic.com.com/networking/?p=532
IOS limitation one week point.
regards,
Pravin
Here is what I encountered when I was trying to do archive on TFTP.
conf t
archive
path tftp://10.0.0.1
end
archive config
%Error opening tftp://10.0.0.1-1 (Timed out)
It is creating -1 itself (which doesn't exist).
I even tried tftp://10.0.0.1/ and the error I get then is:
tftp://10.0.0.1/-1
Cisco URLs are normally in this format:
tftp:[[//location]/directory]/filename
Can you try that?
-serg
-> Sushil
enable the port number 69 on your windows firewall
Jeesemon91
conf t
archive
path ftp://<<FTP,/ TFTP / SFT Server ip>>/Backup file name
time-period 10080 <- in mins
<<To Verify>>
show archive
<<to Clear archive>>
clear archive log config force
