Secondary core switch not pinging from multiple Vlan
Haider Raza
Hi Team,
i have configure two core switches with HSRP for multiple Vlan but primary core switch is pinging from all vlan but unable to ping secondary core switch from Vlans
Kindly suggest the configuration.
Hi, There is some configuration issue,
1. HSRP is configured on VLAN 1 and its allowed on all ports. So some important port is blocked by STP.
2. It is taking time for ICMP reply because HSRP is not stable due to VLAN 1 configuration.
3. Duplicate IP assign on VLAN 2,3, and 4.
4. Preempt is configured on both devices and having the same priority in HSRP protocol. Change priority on one device to make a stable connection.
Please correct that's all things.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
9 Replies 9
Mark Malone
should f0/4 on multi layer sw1 not be a trunk between the 2 switches , theres no config on it
is the hsrp fully formed can you post the show standby brief from each switch
Primery_Core_Switch#sh standby brief
P indicates configured to preempt.
Interface Grp Pri P State Active Standby Virtual IP
Vl1 100 100 P Standby 10.1.227.253 local 10.1.227.254
Secondary_Core_Switch#sh stand bri
Vl1 100 100 P Active local 10.1.227.252 10.1.227.254
Hsrp fully formed ...and tell me what configuration should be done on both switch fa0/4 interface
Deepak Kumar
I don't know your access switch configuration. Please attach the LAB.
Deepak Kumar
Deepak Kumar,
here is i attached the lab and will attached the access switch config.
no issue with your configuration. Your interfaces are not connected properly.
Please share the Packet Tracer file for more investigation.
Deepak Kumar
Deepak Kumar,
please find the attached packet tracer file and suggest the valid configuration for this lab.
Note : just convert this file from jpg file bcoz Pkt file is not sending over this link.
hello,
have you checked my config
Deepak Kumar
Deepak Kumar,
Hi Deepak,
I have an issue with the title
Re: Multiple Core c4500 Deployment
could you please have a look and suggest me with your experiences.
Motiar
