secure devices.
ilnaiduccna
Level 7
Level 7
Hi people,
Can anybody have an idea about on SDM, is this feature available in 2800R.
Thanks in advance,
Naidu.
Tarek
Level 2
Level 2
hello,
I think it is available on this router.
Enter this command.
show flash:
the following files should be present on your router flash.
3 -rwx 2254 Mar 1 2002 00:03:18 +00:00 sdmconfig-8xx.cfg
4 -rwx 833024 Mar 1 2002 00:03:36 +00:00 es.tar
5 -rwx 1052160 Mar 1 2002 00:03:56 +00:00 common.tar
6 -rwx 1038 Mar 1 2002 00:04:07 +00:00 home.shtml
7 -rwx 102400 Mar 1 2002 00:04:19 +00:00 home.tar
8 -rwx 491213 Mar 1 2002 00:04:34 +00:00 128MB.sdf
if not you need you need to install SDM software onto your router flash.
The below fallowing files are present on my router flash is they ok to enable sdm and plz. tell how to enable sdm on 2800R.
Router#sh flash:
-#- --length-- -----date/time------ path
1 17770796 Apr 17 2006 08:55:50 +05:30 c2800nm-entbase-mz.123-14.T7.bin
2 1646 Apr 17 2006 09:04:20 +05:30 sdmconfig-2811.cfg
3 4052480 Apr 17 2006 09:04:48 +05:30 sdm.tar
4 812032 Apr 17 2006 09:05:02 +05:30 es.tar
5 1007616 Apr 17 2006 09:05:18 +05:30 common.tar
6 1038 Apr 17 2006 09:05:32 +05:30 home.shtml
7 113152 Apr 17 2006 09:05:46 +05:30 home.tar
8 511939 Apr 17 2006 09:06:00 +05:30 128MB.sdf
Naidu.
SDM is present on your router
you need to configure the following on your router
ip http server
ip http authentication local
ip http secure-server
then create a user account using this command
username "name" privilege 15 password "password"
