Net flow help
osmansmalik
Community Member
Can i get some help to turn on net flows on my cisco router. I have T1 connection (s0/1/0) and FE port with different sub-interfaces. I want to monitor all my traffic going out the s0/1/0 (WAN) interface.
shiva_ial
Level 4
Level 4
hi,
following link has general commands to
enable netflow
http://manageengine.adventnet.com/products/netflow/help/cisco-netflow/cisco-ios-netflow.html
or an extract from it
router#enable
Password:*****
router#configure terminal
router-2621(config)#interface FastEthernet 0/1
router-2621(config-if)#ip route-cache flow
router-2621(config-if)#exit
router-2621(config)#ip flow-export destination 192.168.9.101 9996
router-2621(config)#ip flow-export source FastEthernet 0/1
router-2621(config)#ip flow-export version 5
router-2621(config)#ip flow-cache timeout active 1
router-2621(config)#ip flow-cache timeout inactive 15
router-2621(config)#snmp-server ifindex persist
router-2621(config)#^Z
router#write
Thanks. My IOS does not support ip route-cache flow.
Can i use ip flow ingress and ip flow egress as a replacement for the route-cache flow command.
Also is F0/1 lan interface or the WAN interface.
Osman
