SecureCRT
anthony.dyne
Level 4
Level 4
Hello
I use SecureCRT version 6 to access routers/switches. there are around 40 switches / routers entry defined with userid/password.
can I move all  entries to another laptop without reentrying all information. I got same securecrt version on the new laptop.
cheers
Anthony
SCOTT ZAHM
Frequent Visitor
Frequent Visitor
The config files are stored in a configuration folder. You can locate by clicking Options, Global Options, and General, at the bottom is the folder location. Copy that folder to the new laptop in it's config directory.
Hope it helps.
Scott
David Johnson
Frequent Visitor
Frequent Visitor
Yes.
Take a look at the configuration of your existing Secure CRT instance with the devices defined:
From main page:
Options -> Global Options -> General -> (at the bottom of General) Configuration Folder
Mine says:
D:\UserData\Documents\SecureCRT\Config
Copy that folder to your new computer - point your new instance to that config folder - should be good to go.
Good Luck
Leo Laohoo
I agree with the previous posts (+5 to both of you).  Look for the "Config" folder and copy everything across.  Don't forget that if you are using login scripts you need to copy that across too.
