security license does not enable on cisco 1900
i copied security  license file from tftp to flash  on cisco 1941 router
it is installed but not enabled.
when i use
license install flash: security k9 .lic  command it shows an error that %error installation failed udi cisco 1900 does not match any file in the system .
?????????what to do ????????
sh flash command shows that security license file in flash but not enabling
Are you 100% sure that the license is for this chassis? It might have been registered with another serial #.
Did you follow this guide:
http://www.cisco.com/en/US/docs/routers/access/1900/hardware/installation/guide/Software_Licenses.html#wp1068079
Ian
