Selective QinQ Tunneling?
Marcin Kurek
Hi Guys,
I have a hard time configuring selective QinQ on 4900M platform. What I would like to achieve is to have some VLANs (e.g. 1-5)  put into QinQ VLAN (e.g. 699) and to pass other VLANs (e.g. 132,133) without outer tag. Here is my configuration:
Switch(config)# interface gigabiethernet0/1
Switch(config-if)# switchport mode trunk
Switch(config-if)# switchport vlan mapping 1-5 dot1q-tunnel 699
Switch(config-if)# exit
However, if I understood the configuration guide correctly the traffic coming from customer network tagged with VLANs other than 1-5 will be dropped.
Every suggestion is welcome
Andrew Gossett
Hi Kurk,
I put this into the lab real quick with ME-3400E's.  On this platform, traffic not matched via vlan mapping command are transmitted unchanged.  However, as you stated, 4900M configuration guide clearly states "Packets with unconfigured vlan_ids are dropped."
With that said, it may be possible to implement a workaround by adding a bogus tag and then stripping it.  For example:
Traffic from vlan 132 and 133 should leave on the uplink with thier original tags whille vlans 1-5 should have the S-tag of 699.  It works in a lab setting for me-3400's.  I imagine it will also work on the 4900M.
-Andy
Hi, Andy,
Your solution is very good idea for the selective Q-in-Q unsupported platform
I've known that N7K also don't support the selective Q-in-Q until now.
If so, is also the selective Q-in-Q available in N7K as your statement ?
Thanks in advance,
- Sungmin
