Sequestering traffic on a router-enabled port
GRANT GATHAGAN
Is there a way to use the "no switchport command to enable routing on a port and yet sequester it from traffic on other vlans within the switch?
The switch in question is a 3750E
Dan Frey
The port can be placed into a vrf and would be isolated from the routing table on the switch.
- Dan
cadet alain
You can also create a RACL  and apply it on this port.
Regards.
Alain
