Serial-to-Ethernet Converter?
Vijay Chawla
Dear Friends,
I have one Cisco 1603 router which got only one Serial & one 10/T Ethernet port,
I need a converter which I can connect top on serial port to connect to my ADSL router via Ethernet port, (this will be used as home router for my practice, thus I don’t want to go for any costly modules…)
Can any one kindly advice/share a link from I can get these type of converter..
Thanks in advance…..
paolo bevilacqua
That is a router, exactly.
thanks for your reply
1603 is Cisco router & other one is ADSL router Click here for this ADSL router:
kindly advce...
http://www.dghcorp.com/ethernet/
This appears to do what you want. I cannot speak from experience
In any case, an old 1600 is too slow for ADSL.
You would end up with a kludge of three devices lined up just to give you bad service.
Get real and buy a good ADSL router. it doesn't even have to be cisco IOS necessarly.
