06-02-2011 07:43 PM - edited 03-06-2019 05:19 PM
Upgraded a 6509 with dual Sup720's to a 6509E Chassis. after installing the 2 SUP720's in the new 6509E chassis the SUPs boot to RMON any time they reload. From RMON I am able to use the boot command to load the IOS. I have used the BOOT= command and SYNC command in RMON. If I use the SET command in RMON the BOOT= command has the correct file and location. Same goes for sh boot in the IOS. What is wrong with the cards in the new Chassis? Nothing has seemd to correct the issue. Thanks!
06-02-2011 07:50 PM
HI -
What is the config-register value? is it 0x2102?
Can you paste the "show bootvar" output of the switch, if you have the output for the "SET" command from ROMMON that would also be great.
ranraju
06-06-2011 07:46 AM
The sup boots right into RMON with no errors. I thought of the config register and checked that right away and it was fine. Even when I look at the boot var in RMON it shows the correct startup. I even reset them and used the SYNC command
OIG_6509>show ver
Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICES_WAN-M), Version 12.2(33)SXH2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Sat 29-Mar-08 13:28 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
OIG_6509 uptime is 18 hours, 58 minutes
Uptime for this control processor is 18 hours, 58 minutes
Time since OIG_6509 switched to active is 18 hours, 58 minutes
System returned to ROM by power cycle at 11:49:04 dst Wed May 7 2008 (SP by power on)
System restarted at 23:41:34 GMT Thu Jun 2 2011
System image file is "bootdisk:s72033-ipservices_wan-mz.122-33.SXH2.bin"
cisco WS-C6509-E (R7000) processor (revision 1.5) with 458720K/65536K bytes of memory.
Processor board ID SMG1450N02K
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
4 Virtual Ethernet interfaces
196 Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
06-02-2011 07:54 PM
Can you post the entire bootup process please?
06-06-2011 07:48 AM
There are no errors in the boot process it just goes right to RMON. I can not post the entire bootup right now. I need to wait for a window to reboot the sup. Here is the sh ver and sh boot from IOS
OIG_6509>show ver
OIG_6509>show boot
BOOT variable = sup-bootdisk:s72033-ipservices_wan-mz.122-33.SXH2.bin,1;
CONFIG_FILE variable =
BOOTLDR variable =
Standby is up
Standby has 524288K/65536K bytes of memory.
Standby BOOT variable = sup-bootdisk:s72033-ipservices_wan-mz.122-33.SXH2.bin,1;
Standby CONFIG_FILE variable =
Standby BOOTLDR variable =
Standby Configuration register is 0x2102
06-06-2011 09:26 AM
Probably the switch supervisor config register is not correct . What you are looking at is the msfc register . Session into the supervisor and take a look at what that is set at . Boot up process is the L2 side supervisor boots first then hands off the L3 supervisor (msfc) to complete booting . If the L2 config register is incorrect then it will go directly into rommon. Use the remote login command to get into the L2 side.
06-06-2011 11:02 AM
Please collect an output of rem com sw sh bootv and make sure the BOOT statements are correct and Configuration register is set to 0x2102.
Best regards,
Andras
