setting an interface back to defaults?
jimmcgrady
Community Member
On a 6500 switch running ios 12.2, is there a way of clearing all config settings for a specified interface?  I want to avoid going through and having to type "no blah blah etc" for each line.
ajay chauhan
Level 11
Level 11
(config)#default interface
Try this.
Ajay
(config-if)#default interface
simionov.adrian
Level 3
Level 3
Using NO commands will not bring the interface to default. For example, some switch models have no shutdown as default, other models have shutdown as default.
As mentioned before, using the command:
you will bring the interface to the default configuration. Please note that this command is a macro inside the IOS, and you can create your own macros.
http://blog.ioshints.info/2007/06/default-interface-configuration-command.html
neil0367389
Visitor
The command even allows you specify which interface (this was actually from packet tracer). Note that on some models the commands may not work
Switch(config)#default interface ?
     Ethernet IEEE 802.3
     FastEthernet FastEthernet IEEE 802.3
     GigabitEthernet GigabitEthernet IEEE 802.3z
     Vlan Catalyst Vlans
     range interface range command
Switch(config)#default interface fa0/1
Building configuration...
Apparently, if for example if you have changed the speed to an interface for example:
Switch(config)#int fa0/1
Switch(config-if)#speed 10
To bring the interface back to its default you can issue the command:
Switch(config-if)#no speed
May need some research this.
