Setting up a password for a switch web interface?
rshah
I am trying to figure out how to set up a username/password for this switch I have.
it is a: Cisco WS-C2924M-XL
It seems to be easy but I couldn't find out how to do it so far.
Any help would be appreciated.. i just started working with this. thanks!
sachinraja
Level 9
Level 9
Hello Ravi
Quite an old switch , isnt it !!! Anyway, See if this URL helps you:
http://cisco.com/en/US/products/hw/switches/ps607/products_installation_and_configuration_guide_chapter09186a008007d32f.html#xtocid2617110
It is basically a configuration guide for the 2900 XL series switches.
Hope this helps.. all the best.. rate replies if found useful..
Raj
Hi!
Are you trying to enable and set username/password for accessing switch through the web-interface? I hope I understood you correctly.
Firstly you need to enable the switch for web-interface.
Enter this command --> ip http-server
Then you can login using the username [admin] and the enable password.
If you want to set some other username for this purpose, then enter this command --> username
Then you can login using the username and the enable password. By default only level 15 access is enabled for the web-interface.
For a lil more have a look at the following URL --> http://www.cisco.com/en/US/tech/tk59/technologies_configuration_example09186a0080178a51.shtml#local
Hope this helps...
AbhisheK
Please rate all helpful posts!!!
