Setting up EIGRP and having issues pining across networks
maceach.m
Hello, I last dived in to working with Cisco's quite a long time ago, and trying to get back into it, but I'm struggling with getting EIGRP working.  Both routers are seeing each other (both got the new adjacency message).  I setup two computers on each switch with static IP's just to keep it easy.  Computer on Switch 1 with Router 1, can ping Router 1 just fine, and the IP of Router 2 that is on Switch 1 as well.  Computer on Switch 2 can ping both interfaces on Router 2, but packets are not coming back from Router 1 when attempting to ping it.  Tracing the packet shows it's making it to Router 1, but it's not responding to the pings.
To simplify, here's the topology in packet tracer I designed, just to experiment with.
Here are the configurations on the routers, starting with Router 1.
Building configuration...
Current configuration : 633 bytes
version 12.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
ip cef
no ipv6 cef
spanning-tree mode pvst
interface FastEthernet0/0
ip address 10.1.1.1 255.0.0.0
duplex auto
speed auto
shutdown
interface FastEthernet0/1
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
router eigrp 10
network 192.168.1.0
auto-summary
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
Now Router 2.
Current configuration : 627 bytes
version 12.4
hostname Router
ip cef
no ipv6 cef
ip address 192.168.1.2 255.255.255.0
duplex auto
speed auto
ip address 172.24.1.1 255.255.0.0
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
router eigrp 10
network 192.168.1.0
auto-summary
ip classless
line con 0
line aux 0
line vty 0 4
login
end
For a bit of hands on, I'm also working with real hardware, and implimented the same thing, still getting the same issue as well, so I'm sure I'm just missing something obvious, but hopefully some fresh eyes will help me.  Thank you.
yeah, exactly, add it in and do the same on the other router, for its subnet.  the do a sh ip route on each router and see if it learned the new route.
let me know how you go
Please remember to rate useful posts, by clicking on the stars below.
Dennis Mink
your eigrp network statements are not including all interfaces? have you done this on purpose, for instance:
172.24.1.1  is not advertised out
No, this is not on purpose..  I'm new, I don't know what to do.
Can you assist in helping me learn how I should be having EIGRP work on all interfaces?  I assumed it happened by default.
EDIT:  Wait, would that be adding "network 172.24.0.0 0.0.255.255"?
Hey, perfect!  It worked on Packet Tracer.  Oddly it didn't actually work on the real hardware we have setup, but the only difference as of right now, is the real hardware we have setup, Router 1 also is doing a NAT to my primary network.  Perhaps the NAT and EIGRP are fighting each other?  Either way, your answer is exactly what I needed, to get this ball rolling, thank you very much.
