10-31-2019 09:28 AM
I've got a Cisco SF300 small business switch 24 port, when reaching my switch with 'putty' it comes up with 8 options e.g. Port Settings then last option is 'Exit'.
I'm looking to enable the command line interface console to use in putty, I've read the Cisco online manual but didn't cover anything about it.
Any help will be much appreciated! I'm currently using the online web portal for my switch.
Kind Regards
Jord
Solved! Go to Solution.
11-03-2019 09:42 AM
10-31-2019 09:50 AM
If understand correctly - you looking to enable SSH for the device - if yes
follow below procedure :
https://helpdeskgeek.com/how-to/configure-ssh-access-cisco-sg300-switches/
=====️ Preenayamo Vasudevam ️=====
11-01-2019 08:57 AM - edited 11-01-2019 11:41 AM
Hi @balaji.bandi ,
I followed these steps, the SSH is already enabled on the switch although the option isn't there when creating / editing either user? Screenshot below.
When trying to use SSH port 23 in PUTTY it displays 'Connection Refused' without even having chance to login.
Screenshot below.
11-03-2019 09:42 AM
Resolved issue by updating firmware & boot firmware.
