SFP-10GBase-SR for 3850X
Patrick McHenry
Level 4
Level 4
Hi, quick question - are the SFP-10GBase-SR modules or is it SFP-10GBase-SR+ that we use in our 2960x and 3750xs compatible with 3850xs?
TenGigabitEthernet1/0/1 is up, line protocol is up (connected)
  Hardware is Ten Gigabit Ethernet, address is 44e4.d948.3233 (bia 44e4.d948.3233)
  Description: UPLINK NAS-10G-CORE-SW1 | Eth1/6
  MTU 1500 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
  Keepalive not set
  Full-duplex, 10Gb/s, link type is auto, media type is SFP-10GBase-SR
Thank you
6 Replies 6
Arunagiri Nallusamy
Hi Patrick,
SFP-10G-SR is supported in the 3850 switches from IOS version 3.2.0 SE onwards. Please refer Table 4 in the following link for reference.
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6974.html
Arun
Thanks Arun,
What image are the 3850s currently being shipped with? Also, I thought the 3850s use the new XE software, no?
Thank you
Hi Patrick,
The 3850 switches were shipped with 3.2.0SE by default some time back. I am not sure if the factory installed version has changed recently. However, our suggestion is to use 3.3.2 (stable release) as major bugs have been fixed starting from this IOS version.
Arun
Arun,
don't the 3850s run the XE image instead of IOS?
Also, are you saying that before vers 3.2.0SE, 3850s did not support the SFP-10G-SR Gbic?
Thank you
Patrick,
Here is the latest image shipped with the switch I just got 2 months ago. The device also has 2 10Gig interfaces..
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.02.02.SE RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Fri 14-Jun-13 19:24 by prod_rel_team
Hi Patrick,
Yes, the 3850's does run the XE image. We refer it as IOS-XE images. No, the SFP-10G-SR is supported only from the mentioned release.
Arun
