SFP Module for Long Distance
hugo_garcia
Hi everybody,
i have a doubt, can i use a SFP GLC-LH-SM to MMF (Multi Mode Fiber) ??
Hugo
5 Replies 5
Collin Clark
Yes, but there are some limitations. Please refer to Table 6 in the following document.
http://cisco.com/en/US/products/hw/routers/ps341/prod_module_installation_guide09186a00801cc731.html
We did happen upon an issue where using the LX/LH moudules over 50um MMF over distances around 200m-250m where we discovered DMD (Differential Mode delay) and had to use relatively costly mode-conditioning patch cables to confirm the condition.
The symptoms that led to this discovery were fairly limited to "input errors" on both end of some trunk links. We're talking about 1 to 2 errors a week. In our case we just went to SX modules and all issues cleared.
Our interfaces never came up and we too had to use conditioning cables.
thanks for the information, i'll check it.
regards,
Hugo
i found next link about GLC-LH-SM SFP where it show this module to both MMF and SMF:
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6981.html
Hugo
