SFP modules check fake or not?
Oleg Volkov
Dear Sirs!
My friend, buy few SFP GLC-T modules as original Cisco.
But I never see serial numbers like this:
00000MTC1719055H
00000MTC171903XL
00000MTC171907RX
00000MTC171909B6
N5596-S5# sh int ethernet 1/45 transceiver sprom
Ethernet1/45
    transceiver is present
    type is SFP-1000BASE-T
    name is CISCO-METHODE
    part number is SP7041_Rev_F
    revision is F
    serial number is 00000MTC1719055H
    nominal bitrate is 1300 MBit/sec
    Link length supported for copper is 100 m
    cisco id is --
    cisco extended id number is 4
  Identifier                      : 0x03 (SFP)
  Ext_Identifier                  : 0x04
  Connector                       : 0x00 (Unknown)
  Infiniband Compliance Code      : 0x00 (None)
  Sonet Compliance Code           : 0x0000
  Gigabit Ethernet Compliance Code: 0x08 (1000Base-T)
  Encoding                        : 0x01 (8B/10B)
  BR_Nominal                      : 0x0d  [1300]
  Reserved1                       : 0x00
  Length_9u_1                     : 0x00  0 KM
  Length_9u_2                     : 0x00  0 Meters
  Length_50u                      : 0x00  0 Meters
  Length_60u                      : 0x00  0 Meters
  Length_Copper                   : 0x64  100 Meters
  Reserved2                       : 0x00
  Vendor Name                     : CISCO-METHODE
  Reserved3                       : 0x01
  Vendor OUI                      : 0x000000
  Vendor Part No                  : SP7041_Rev_F
  Vendor Revision                 : F
  Reserved4                       : 0x410cc1
  Check Code ID                   : 0x5a (OK)
  Options                         : 0x0010
  BR Max                          : 0x00
  BR Min                          : 0x00
  Vendor Serial No                : 00000MTC1719055H
  Date Code                       : 13051801
  Diagnostic Monitoring Type      : 0x00
  enchancedOptions                : 0x00
  SFF8472Compliance               : 0x00
  Check Code EXT                  : 0x2b (OK)
  Vendor Specific ID Data         : 0x00000e51bd4a5e876029cc2b092dba4d
                                  : 0x0ff1fd000000000000000000ebafbb73
What can I check this modules? this original Cisco or fake?
Dear Sirs who have Nexus 5xxx switch and inserted original GLC-T modules - please, send me "transceiver sprom" out
Thanks!
Helping seriously ill children, all together. All information about this, is posted on my blog
Richard Primm
hello Oleg,
I checked the serial numbers you listed and they are real Cisco GLC-T and fully covered.  Nothing to worry about.
-Luke
Richard Primm
hello Oleg,
-Luke
augusto
Hi, how can I check if it is Cisco Original, can I check my self ?
have this 4 items to check
FNS130301D3
FNS12200XVX
FNS12210CF2
FNS13230XLN
Elrick Landon
I plan to buy two SFP module for my switch device WS-C2960X-24TS-LL.
A lots of model are compliant with my device, but it's impossible to know différences... so crazy !!
I think that GLC-SX-MMD reference seems the best ... ?!
A lots of SFP Module are available on EBay or another website...
How can i know if this SFP Module are genuine or Counterfeit/fake module ?
Does it can be possible to enter the serial number somewhere to know it myself ?
Does any information present on the stick can be usefull to challenge it ?
Best Regards.
Hi , You can check serial numbers in the Cisco trade tool , but a Cisco login is required. The tool display part-ID (even bundle part-ID country of manufacturer.
https://gcta.cloudapps.cisco.com/FinAdm/GCTA/servlet/ControllerServlet?action=coInfo
