SFP not Working in Catalyst 4948E
ishtiaqiqbal
Hello Everyone I have 2 switches Catalyst 4948GE with 10 X2 converter and Catalyst 4948E that have 4 SFP 10Gig Ports. I have bought huawei 10G SFP that are working very fine in 4948GE with X2 Converter but not in 4948E . It giving the error "Transceiver integrity check on port Te1/52 failed: bad crc". Please guide me how to resolve the issue. I want to replace 4948GE with 4948E.
Reza Sharifi
Not all 3rd party vendor SFPs work with Cisco switches.  You may want to try a different SFP from a different vendor or purchase one from a Cisco partner/reseller.
Deepak Kumar
Not all SFPs are not compatible with any Cisco switch. You must buy a compatible SPF for the Cisco Switch.
Here are the list and guide for Cisco 4948E
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4900/4948E/installation/guide/4948E_ins/0Bxcvrs.html
Here is the Cisco tool to find the best suitable SPF:
https://tmgmatrix.cisco.com/home
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Dear
If they are not supported then how are these working in Catalyst 4948GE
Both Switches are different. What is IOS version on both switch? Also, share SFP details.
Have you trined "service unsupported-transceiver" command?
Deepak Kumar
Deepak Kumar,
