SFP with a lot of errors / the LED is orange
tarik sayel
I need to connecte Cisco switch 3750 with a huawei DSLAM with FO, i try to connect them with LX SFP, but the cisco side (that i manage) still with led orange, and a lot of errors when a use show interface x/x.
please any idea
interface GigabitEthernet1/0/25
switchport mode access
logging event spanning-tree
logging event status
speed nonegotiate
sh int GigabitEthernet1/0/25
GigabitEthernet1/0/25 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is a40c.c3fa.f419 (bia a40c.c3fa.f419)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 184/255, txload 1/255, rxload 1/255
  Keepalive not set
  Full-duplex, 1000Mb/s, link type is force-up, media type is 1000BaseLX SFP
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:01, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     379 packets input, 47094 bytes, 0 no buffer
     Received 379 broadcasts (376 multicasts)
     197 runts, 0 giants, 0 throttles
     197 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 376 multicast, 0 pause input
     189 packets output, 26558 bytes, 0 underruns
Leo Laohoo
You got a bad fibre line.  The value I've highlighted should always be "255" and nothing less.
12 Replies 12
Leo Laohoo
thanks for all,
the issue was solved, by using an other type of SFP on the huawei side
BR
Thanks for taking the time to rate our posts.
InayathUlla Sharieff
Simple Layer 1 issue. :-)
Hey Inayath,
Have you seen a link type like this?  "force-up"?  I don't remember seeing this.
Leo,
I didnt see it or might not have noticed it.
Anyhow this is the explanation for it:
If either device does not support gigabit auto-negotiation , disabling gig auto-negotiation will force the link up henc eyou see that. (AS you know the switch default to link type Auto).
Yes, you are right InayathUlla about "force-up" .
I am right but no rating for me :-) just joking.
Have a nice day we are happy your issue has been resolved.
Rated, Inayath.
Yeah thanks dear leo.
Sent you an email, Inayath.
Leo, Didnt recieve yet....
