SFTP doesn't work on 9200 switch
Vinod
Hello, can anyone please help me to export the config to SFTP destination? I can upload files using winnows cmd but not from the cisco switch. SFTP is hosted on Azure
Error message %Error writing sftp://*:*@IP-address/test (Undefined error)
6 Replies 6
DanielP211
Which command are you using? Do you have access to azure from the switch IP's on your firewall?
BR
****Kindly rate all useful posts*****
Vinod
Yes, connection is open on switch for Azure over ssh
I use command copy running-config sftp:
Ensure that the Cisco switch can reach the Azure SFTP server over the network.
Check for any firewall rules or network restrictions that might be blocking the connection.
Check the logs on your Azure SFTP server for any error messages or authentication failures that might shed light on the issue
switch# copy running-config sftp://username@IP-address/directory/filename
balaji.bandi
This showsr far end SFTP server  denied  for some reason - check the SFTP Logs
BB
on azure side it shows Unknown error 403.  I don't find any other details
