SG300 - 28P - upgrade
yaloosh
Hello
i would like to upgrade my cisco sg300 28p with latest firmware version.
currently switch is running: Firmware Version (Active Image): 1.2.7.76
with boot version - 1.1.0.6
i can't find latest version for that model, in addition, do i need to upgrade the boot version as well?
10x.
3 Accepted Solutions
balaji.bandi
Firmware upgrade take care of all as per i know this models.
1.4.X is the latest here is the link.
https://www.cisco.com/c/en/us/support/switches/sg300-28-28-port-gigabit-managed-switch/model.html#~tab-downloads
BB
Mohsin Alam
You can download from here :
https://software.cisco.com/download/home/283019611/type/282463181/release/1.4.11.5
make sure you go through the release notes as well.
## Make sure to mark post as helpful, If it resolved your issue. ##
yaloosh
i was trying to upload sx300_fw-14115.ros, but i'm getting error
Error Message:Illegal software format
7 Replies 7
balaji.bandi
BB
Mohsin Alam
yaloosh
You need to step upgrade 1.3 then 1.4.X i guess here :
get below one test it, take the config backup all them when you upgrade to new version.
https://software.cisco.com/download/home/283019617/type/282463181/release/1.3.7.18
BB
i as able to install 1.3.7.18 , but when trying to upload sx300_fw-14115.ros , i'm getting error "SW code file is over sized"
how do i delete the old image from switch?
i access to switch directory by "dir", then delete image-2
switch4fdc60#delete image-2
Delete flash://image-2? (Y/N)[N] Y
Delete operation is not permitted on file flash://image-2
please advice.
 - FYI : https://community.cisco.com/t5/small-business-switches/sg300-28p-firmware-upgrade-error/td-p/2493508
 M.
