change carrier-delay Nexus 3064
santox
Hi, I have a Nexus 3064 version 6.0(2)U6(7)  where I connected a L2 protected.
When I have a fiber cut, provider switch automatically to backup line withouth problem. When master is going up, they cant switch to the master because flap of Nexus port is <50ms.
They tell me to
"be able to advise how to increase “carrier-delay down” time on your ports in order to not send LOS during protection switch (sub 50ms flaps)."
I try to find something on the internet but I cant.
Someone can help me to try a way to fix this?
have a nice day
balaji.bandi
You need to change carrier delay so networkl will co-up with suggestions :
look at the config :  ( nexus 7K, same config works on nexus 3K)
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/nx-os/interfaces/configuration/guide/b-Cisco-Nexus-7000-Series-NX-OS-Interfaces-Configuration-Guide-Book/configuring-basic-interface-parameters.html#concept_28B89D703CF64255A8022A2C645E90E9
BB
ok man I will try this config.
Provider tells me that I must do the change in phisical port and not in vlan so I dont try this command.
Now I do a test and let u know.
Thank you again and have a nice day
Hi we try but doesnt work
Nexus port send LOS in case of sub 50ms service flaps so this command doest have effect on it.
