sg350 interface vlan issues
Manish Manwal
Hi all, I am facing some issues in sg350 and sg300 smb series. Our enterprise switches have management vlan 52 configured. And I want to configure all smb switches management vlan as our enterprise switches (vlan 52). I configured vlan 52 and then put ip address on it. But when I ping it, it is not replying. Only vlan 1 ip address is replying.
THANKS
MANISH MANWAL
12 Replies 12
balaji.bandi
how are these devices connection, have you allowed  VLAN52 in the trunk
BB
hi balaji.bandi, i have allow all vlan in trunk ports. vlan 52 also there.
THANKS
MANISH MANWAL
is this VLAN 52 configured on SMB device is SVI  ? can you post example configuraion ?
BB
interface vlan 1
end users
ip address 10.10.10.19 255.255.255.0
no ip address dhcp
interface vlan 41
management vlan
ip address 192.168.135.158 255.255.255.224
THANKS
MANISH MANWAL
interface vlan 41    <---- as per your description this should be VLAN 52 right ?
management vlan
BB
I am not sure about this particular small business switch but many layer 2 switches want to have only a single layer 3 SVI active. What happens is your shut down interface vlan 1 or remove the IP address from that vlan interface?
Rick
Rick
we removed ip address of vlan 1 but still not working. please see attachment for reference.
THANKS
MANISH MANWAL
Manish
Thank you for trying my suggestion of removing the vlan 1 interface and for the output demonstrating that the switch has one interface and that it is up. I am sorry that this did not solve your problem. Can you post the output of show arp (or perhaps show ip arp).
I am not sure if this switch supports CDP but if it does would you post the output of show cdp neighbor detail
Rick
Rick
#sh arp
Total number of entries: 1
VLAN Interface IP address HW address status
vlan 52 10.10.10.24 24:7e:12:d9:73:42 dynamic
sh cdp neighbors
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater, P - VoIP Phone
M - Remotely-Managed Device, C - CAST Phone Port,
W - Two-Port MAC Relay
Device ID Local Adv Time To Capability Platform Port ID
Interface Ver. Live
DSW1.MALIK.AKUMS gi9 2 131 S I cisco GigabitEthe
WS-C2960X-24 rnet1/0/24
TS-L
DSW1.PLANT2.Akums gi10 2 160 S I cisco GigabitEthe
WS-C2960XR-2 rnet1/0/24
4TS-I
sh ip arp command not supported in this switch model
THANKS
MANISH MANWAL
Manish
Thank you for the additional information. I am somewhat confused about the addressing being used. In an earlier post you indicated that the IP address for vlan 1 was 10.10.10.19. But the interface for vlan 52 is using address 10.10.10.241. How can 2 vlans have addresses in the same subnet? Can you clarify this?
The output of show arp indicates that there is one device that your switch should be able to communicate with. What is the device with IP 10.10.10.24? Can you ping that IP address?
I am glad to see that this switch does support cdp. Can you post the output of show cdp neighbor detail
Rick
Rick
whatever i post in starting for this they just an example. we are using 10.10.10.0/24 network for management vlan(52). they can ping with each other. but when we ping smb switches by any pc it is not pinging. and same vlan when we pc to enterprise switches its working.
THANKS
MANISH MANWAL
Yes right, but this is just n example.
THANKS
MANISH MANWAL
