sg550-28p is restarting cyclically when switched on
belve0001
I have not so advanced but also not used sg550-28p cisco switch. Our college has obtained it as a donation from a sponsor.
It was unpacked and looks like completely not used and new device. The switch was switched on with serial blue cable and putty terminal. But the following message with FATAL ERROR has appeared cyclically during initial booting.
Does anybody from cisco community could advise me what to do? Has sg550-28p linux based os any possibility to interrupt the booting and repair linux os based files?
Thanks a lot in advance.
************ the msg body ******************
Sent SIGKILL to all processes
Requesting system reboot
BootROM 1.41
Booting from NAND flash
MTL, DNI MPP 13 output high..
General initialization - Version: 1.0.0
Serdes initialization - Version: 1.0.2
DDR3 Training Sequence - Ver TIP-1.22.0
DDR3 Training Sequence - Switching XBAR Window to FastPath Window
DDR3 Training Sequence - Ended Successfully
BootROM: Image checksum verification PASSED
ROS Booton: Jul 26 2015 14:46:31
Press x to choose XMODEM...
Running UBOOT...
U-Boot 2013.01 (Jul 26 2015 - 14:46:18) Marvell version: 2014_T3.0_eng_dropv61.1.0
Loading system/images/active-image ...
Sun Jul 26 02:36:00 UTC 2015
[H[JLinux MARVELL_LINUX 3.4.69 #11 SMP Thu Jul 30 16:07:12 IDT 2015
MAC Address   :  0c:f5:a4:22:47:01.
Autoboot in 2 seconds - press RETURN or Esc. to abort and enter prom.
*** Running  SW  Ver. 2.1.0.34  Date Jul 30 2015  Time 16:06:52 ***
HW version is 00.00.01
Base Mac address is: 0c:f5:a4:22:47:01
Dram size is  : 512M bytes
Dram first block size is  : 370688K bytes
Dram first PTR is  : 0x80000000
Dram second block size is  : 4096K bytes
Dram second PTR is  : 0x19000000
Flash size is: 256M
26-Jul-2015 02:36:09 %CDB-I-LOADCONFIG: Loading running configuration.
26-Jul-2015 02:36:09 %CDB-I-LOADCONFIG: Loading startup configuration.
Device configuration:
Slot 1 - SG350-28P
Device 0: GT_98DX3235 (AlleyCat3)
-- Unit Number 1                  --
26-Jul-2015 02:36:25 %INIT-I-InitCompleted: Initialization task is completed
-- Unit Number 1  Master Enabled –
Tapi Version: v1.9.7
Core Version: v1.9.7
26-Jul-2015 02:36:30 %Environment-W-RPS-STAT-MSG: Power supply source changed to Main Power Supply.
26-Jul-2015 02:36:31 %MLDP-I-MASTER: Switching to the Master Mode.
26-Jul-2015 02:36:31 %Entity-I-SEND-ENT-CONF-CHANGE-TRAP: entity configuration change trap.
26-Jul-2015 02:36:31 %Environment-W-RPS-STAT-MSG: Power supply source changed to Main Power Supply.
26-Jul-2015 02:36:33 %HAL_config_poe-F-POEInitError: HALP_config_poe_692xx_check_master_reset: HALP_config_poe_number_of_poe_devices is Zero: Failed on init.
***** FATAL ERROR *****
Reporting Task: HCPT.
Software Version: 2.1.0.34 (date Jul 30 2015 time 16:06:52)
ros(HOSTG_fatal_error+0x14) [0x2332e4]
ros(OSSYSG_fatal_error+0x148) [0x74b314]
ros() [0x580724]
ros(HALP_config_poe_692xx_dev_op_set_periodic+0x4f0) [0xa07ce8]
ros() [0x9fbf68]
ros(HALP_config_poe_691xx_692xx_poe_dev_operation+0x48) [0x9fc04c]
ros(HALC_config_poe_dev_operation+0x44) [0xa0b198]
ros() [0x9b3218]
ros(HALC_config_device_dispatch+0x1a8) [0x9b7f3c]
ros() [0x9cf2b4]
ros() [0x9cf4c0]
ros() [0x9cf518]
/lib/libp2linux.so.1(+0x3aa4) [0xb6f4faa4]
/lib/libpthread.so.0(+0x6e64) [0xb6f2ae64]
***** END OF FATAL ERROR *****
*****************  SYSTEM RESET  *****************
The system is going down NOW!
Sent SIGTERM to all processes
BootROM 1.41
Running UBOOT...
AND SO ON....
8 Replies 8
belve0001
sorry sg350-28p of course
Julio E. Moisa
Have you upgraded the image recently?
ros() [0x580724]
I have not experienced this issue before but I suggest open the case with the Small Business Switches section:
https://supportforums.cisco.com/t5/small-business-switches/bd-p/5976-discussions-small-business-switches
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
thank you but sg350-28p has not provided me with any chance to upgrade or to do anything :-)  I can only observe the endless booting process :-)
Thank you, I think it should be escalated to the Small Business secction to get a better answer. If you have the warranty it could be replaced.
Thank you and I escalated the topic to the Small Business section without any possibility to replace this lucky device from cisco. Because it was just a donation ...
I recently ran into the same issue that was raised above.  I was able to recover the switch by interrupting the boot process by pressing "x" to choose XMODEM and transferring the Cisco image 2.1.0.63 over to the switch via an XMODEM transfer.  In order to accomplish this, you have to have a direct connection from a laptop via console and application which supports the ability to transfer files using XMODEM (not XMODEM 1K) protocol.  The process is similar to the recovery process for other Cisco Switches when an Image file is not accessible.
Please mark this post as a solution or helpful if you feel this was useful or the solution to the issue
kamik
replacement of the controller PD69208M  helped me
