03-30-2015 01:31 AM - edited 03-07-2019 11:18 PM
I have a route link between 2 sites, Its a 5G on a 10G Bearer. The Switch ports on either side are 10G ports. I want to apply some sort of traffic shaping to allow a maximum of 5G over the link. Considering its 10G ports and 5G link. Topology is as follows
6880x (10G Port)-------5G Link---------(10G Port) Nexus 9k
Any ideas how this can be achieved?
03-30-2015 09:27 AM
You don't necessarily need to do anything considering some modules on the 6800 are oversubscribed.
see table-2 in this link:
16P 10G at 2:1 in oversubscription mode (default) for base module and port cards
8P 10G at 1:1 in performance mode (configurable) for base module and port cards
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-6880-x-switch/data_sheet_c78-728228.html
Also, you can monitor these ports over a period of time and figure out the average traffic traversing the link. If the link is 5Gig and you are only pushing one or 2 gig, than you are fine, but if you see lots of packet drops on the interfaces than maybe some sort of traffic shaping/queuing might be helpful.
03-31-2015 12:12 AM
Thanks Reza
I understand currently we may not hit the full 5G bandwidth but this will become a DCI link and we are gradually running more and more traffic over it so I was planning to put some shaping in place before even dropping any packets.
Just checking if anyone has done this before
03-31-2015 05:54 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Traditionally, many Cisco switches lack many QoS features found on Cisco routers. Shaping is often such a feature. (Policing is often available, but just dropping overrate traffic is what you're trying to avoid.)
What I would suggest is consulting your IOS version configuration guide's chapter on QoS features, for both your platforms, and see if shaping is offered.
If it's not, you're a bit stuck unless you interpose a more QoS feature rich device between your existing devices and the 5G link.
