Show Interface trunk
fsebera
Level 9
Level 9
With the following config on a Cisco 3845 router, I cannot seem to figure out why I cannot see the trunk details with show interface trunk command.
Ping, traceroute, EIGRP, iBGP peering is operational but no trunk details on the router side.
On Cisco 3845 router, IOS
c3845-advipservicesk9-mz.124-11.XJ4.bin
show interface trunk - no output
On peering Cisco 3750e switch
C3750e#sh int trunk
Port Mode Encapsulation Status Native vlan
Gi1/0/5 on 802.1q trunking 4
Gi1/0/6 on 802.1q trunking 4
Port Vlans allowed on trunk
Gi1/0/5 1-4094
Gi1/0/6 1-4094
Port Vlans allowed and active in management domain
Gi1/0/5 1-2,4-7
Gi1/0/6 1-2,4-7
Port Vlans in spanning tree forwarding state and not pruned
Gi1/0/5 1-2,4-7
Gi1/0/6 1-2,4-7
ROUTER 3845 config
vlan 2
name OER-2
vlan 4
name OER-4
vlan 5
name OER-5
vlan 6
name OER-6
vlan 7
name OER-7
interface GigabitEthernet0/0
no ip address
interface GigabitEthernet0/0.1
encapsulation dot1Q 1
ip address 172.26.1.1 255.255.255.240
interface GigabitEthernet0/0.2
encapsulation dot1Q 2
ip address 172.26.2.1 255.255.255.240
interface GigabitEthernet0/0.4
encapsulation dot1Q 4 native
ip address 172.26.4.1 255.255.255.0
interface GigabitEthernet0/0.5
encapsulation dot1Q 5
ip address 172.26.5.1 255.255.255.0
interface GigabitEthernet0/0.6
encapsulation dot1Q 6
ip address 172.26.6.1 255.255.255.0
interface GigabitEthernet0/0.7
encapsulation dot1Q 7
ip address 172.26.7.1 255.255.255.0
Cisco 3750e config
vlan 2
name OER-2
vlan 4
name OER-4
vlan 5
name OER-5
vlan 6
name OER-6
vlan 7
name OER-7
C3750e#sh run int g1/0/5
interface GigabitEthernet1/0/5
description master-connector
switchport trunk native vlan 4
switchport mode trunk
Tks
Frank
Hello Franck,
just a moment you have routed subinterfaces on the C3845 not a L2 trunk!
for seeing packets for vlans and the associated subintefaces use
sh vlan
or
sh vlans
(this is IOS dependent in 12.4 should be sh vlans)
this can tell you how much traffic is sent and received on each vlan and the corresponding subinterfaces
traffic is divided for L3 protocol (ipv4, ipx , ipv6)
Hope to help
Giuseppe
9 Replies 9
bretjaquish
Level 6
Level 6
I searched for this command on my 2821. It is in the IOS but gives no information.
I looked through the master command index for 12.4 and 12.4T. The command is NOT shown in either of those.
The IOS command lookup tool was able to find it.
It looks like it is only supported on the 6500 series chassis. It was introduced for the Supervisor 2 and then added for the SUP720.
Link to the tool:
http://tools.cisco.com/Support/CLILookup/cltSearchAction.do?Application_ID=CLT&IndexId=IOS&IndexOptionId=123&SearchPhrase="*"&Paging=25&ActionType=getCommandList&Bookmark=True
Release Modification
12.2(14)SX
Support for this command was introduced on the Supervisor Engine 720.
12.2(17d)SXB
Support for this command on the Supervisor Engine 2 was extended to Release 12.2(17d)SXB.
12.2(33)SRA
This command was integrated into Cisco IOS Release 12.2(33)SRA.
12.2(33)SXI
This command was changed to add the optional vlan vlan keyword and argument.
Hi Bret,
I used this setup on my 7206VXR running IOS 12.4T last year and all was good then.
Perhaps the Cisco 3845 programmers were under time constraints and just missed this one.
I guess as long as it works and passes traffic I should be happy!!!
Thanks again
Frank
No problem. A little fancy googling showed that it would work in a 7600 series router. It might be haphazardly implemented on the routing platforms.
Hello Frank,
sh int trunk is very handy and I use it on C6500 and C4500 it comes from the old sh trunk in CatOS.
However, not all IOS based switches support it.
the less readable alternate way in those switches is to use
sh int type x/y switchport
I would try if it works for your C3845.
Hope to help
Giuseppe
Thanks, it's a no go.
Switchport option not available but tried it anyway :).
I list the output from two different subinterfaces and both provide the same details -
Perhaps the description line should read -- SEE VISIO DOCUMENTATION!!!!
Thanks again
OER-Master1#sh int gigabitEthernet 0/0.4 switchport
% Invalid input detected at '^' marker.
OER-Master1#sh int gigabitEthernet 0/0.4 ?
aaa dot11 aaa information
dampening Show interface dampening info
description Show interface description
mpls-exp Show interface MPLS experimental accounting info
precedence Show interface precedence accounting info
rate-limit Show interface rate-limit info
| Output modifiers
GigabitEthernet0/0.4 is up, line protocol is up
Hardware is BCM1125 Internal MAC, address is 0023.5eae.1f90 (bia 0023.5eae.1f90)
Internet address is 172.26.4.1/24
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Encapsulation 802.1Q Virtual LAN, Vlan ID 4.
OER-Master1#sh int gigabitEthernet 0/0.7
GigabitEthernet0/0.7 is up, line protocol is up
Internet address is 172.26.7.1/24
Encapsulation 802.1Q Virtual LAN, Vlan ID 7.
Hello Franck,
sh vlan
or
sh vlans
Hope to help
Giuseppe
Duh, I am so ruined.
YOU ARE CORRECT.
Turns out, trunking is not a valid verb.
My sub-interfaces are not allowed to be layer-2 interfaces - only layer-3.
I guess the 3750e switch "TRUNKING" mislead me into thinking I was creating layer-2 interfaces and the subs were the layer-3 portion. It appears I need a switchport module to make use of the vlans on the 3845 router....
OER-Master1#sh vlans
Virtual LAN ID: 1 (IEEE 802.1Q Encapsulation)
vLAN Trunk Interface: GigabitEthernet0/0.1
Protocols Configured: Address: Received: Transmitted:
IP 172.26.1.1 2506 2508
Other 0 199
2701 packets, 374945 bytes input
2707 packets, 371210 bytes output
Virtual LAN ID: 2 (IEEE 802.1Q Encapsulation)
vLAN Trunk Interface: GigabitEthernet0/0.2
IP 172.26.2.1 2544 2550
Other 0 4
2544 packets, 298974 bytes input
2554 packets, 299355 bytes output
Virtual LAN ID: 4 (IEEE 802.1Q Encapsulation)
vLAN Trunk Interface: GigabitEthernet0/0.4
This is configured as native Vlan for the following interface(s) :
GigabitEthernet0/0
IP 172.26.4.1 2549 4800
Other 0 4
2935 packets, 312323 bytes input
4804 packets, 410704 bytes output
Virtual LAN ID: 5 (IEEE 802.1Q Encapsulation)
vLAN Trunk Interface: GigabitEthernet0/0.5
IP 172.26.5.1 2756 2954
Other 0 4
2756 packets, 315709 bytes input
2958 packets, 327241 bytes output
Virtual LAN ID: 6 (IEEE 802.1Q Encapsulation)
vLAN Trunk Interface: GigabitEthernet0/0.6
IP 172.26.6.1 4789 2554
Other 0 4
4789 packets, 442759 bytes input
2558 packets, 299860 bytes output
Virtual LAN ID: 7 (IEEE 802.1Q Encapsulation)
vLAN Trunk Interface: GigabitEthernet0/0.7
IP 172.26.7.1 2513 2521
Other 0 4
2513 packets, 296666 bytes input
2526 packets, 298303 bytes output
The only way "sh int trunk" would work in a 3845 is if it had hwic switchcard in one of the slots and you set up trunking on one of those ports , as previously stated it won't work on a routed port with subinterfaces.
Yours cleared it up the best.  Makes sense the command is available in the IoS to support switching module cards.  I couldn't for the life of me understand why they would leave it in if it was useless. Although it would also make sense that when configuring router-on-a-stick that the command would work to list the encaps on the sub-interfaces. Would be a much quicker and more efficient way to check trunk set-up.  But at least now I know why it never works on a router, and only on a switch.
