show ver for a specific module of a 3850 stack
marcocanova74
Good morning,
i wiuld like to run a "show ver" command on a specific module of a 3850 stack. Basically I need to understand the reload reason.
On 3750 I simply opened a session on the module and run "show ver"; unfortunately on 3850 the situation is changed, I can't run this command:
SwMag-1000-CRoom-2(diag)#show
  ap            Cisco access point information
  avc           Show AVC Information
  buffers       Buffer pool statistics
  checkpoint    Checkpoint Facility (CF) and halib
  exception     Exception handling information
  ffm           Properties of a single Forwarding and Feature Manager instance
  guest-lan     Show Guest WLAN Configuraton
  iif           Interface ID Factory info
  l2tp          Show active L2TP sessions
  license       Display licenses.
  logging       Show the contents of the logging buffer
  mgmt-infra    Management infra
  onboard       no description
  oscore        core-os information
  package       Show posix clients compatibility
  pds           Show PDS information
  processes     Active process statistics
  rom-monitor   Show ROMMON version information
  romvar        Romvar information
  sdm           SDM
  software      no description
  tech-support  Show tech support commands
  voltage       Voltage Margins
  wireless      Show wireless specific configuration
  wlan          Show WLAN Configuraton
The crash info is not meaningful:
SwMag-1000-CRoom-2#dir crashinfo-7:
Directory of crashinfo-7:/
   11  -rw-           0   Jan 1 1970 01:00:06 +01:00  koops.dat
   12  -rw-           0  Dec 16 2017 16:53:04 +01:00  cilogs
Thank you for your help
Best regards
Marco Canova
Maksim Urmanov
Hello, each stack member should have its own crash folder.  it depends on amount of members in your installation.
Try to find crashlog info using following command:
dir crashinfo-1:
Add required member number by yourself
Hi Maksim, I already performed the command for the switch I need to have the information (the #7)
Leo Laohoo
Post the complete output to the command "sh version".
Here, below the output but note I need to undersatnd why the member #7 rebooted.
thank you
mc
SwMag-1000-CRoom-2#sh ver
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 03.06.03E RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Wed 26-Aug-15 11:22 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2015 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: CAT3K_CAA Boot Loader (CAT3K_CAA-HBOOT-M) Version 3.58, RELEASE SOFTWARE (P)
SwMag-1000-CRoom-2 uptime is 4 weeks, 4 hours, 26 minutes
Uptime for this control processor is 4 weeks, 4 hours, 32 minutes
System returned to ROM by Power Failure
System restarted at 07:02:35 GMT Mon Nov 20 2017
System image file is "flash:packages.conf"
Last reload reason: Power Failure
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: Ipbase
License Type: Permanent
Next reload license Level: Ipbase
cisco WS-C3850-48P (MIPS) processor with 4194304K bytes of physical memory.
Processor board ID FCW2029D1JZ
2 Virtual Ethernet interfaces
364 Gigabit Ethernet interfaces
28 Ten Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
252000K bytes of Crash Files at crashinfo:.
252000K bytes of Crash Files at crashinfo-1:.
252000K bytes of Crash Files at crashinfo-2:.
252000K bytes of Crash Files at crashinfo-3:.
252000K bytes of Crash Files at crashinfo-4:.
252000K bytes of Crash Files at crashinfo-6:.
252000K bytes of Crash Files at crashinfo-7:.
1611414K bytes of Flash at flash:.
1611414K bytes of Flash at flash-1:.
1611414K bytes of Flash at flash-2:.
1611414K bytes of Flash at flash-3:.
1611414K bytes of Flash at flash-4:.
1611414K bytes of Flash at flash-6:.
1611414K bytes of Flash at flash-7:.
0K bytes of Dummy USB Flash at usbflash0:.
0K bytes of Dummy USB Flash at usbflash0-1:.
0K bytes of Dummy USB Flash at usbflash0-2:.
0K bytes of Dummy USB Flash at usbflash0-3:.
0K bytes of Dummy USB Flash at usbflash0-4:.
0K bytes of Dummy USB Flash at usbflash0-6:.
0K bytes of Dummy USB Flash at usbflash0-7:.
0K bytes of at webui:.
Base Ethernet MAC Address : d4:2c:44:a6:af:80
Motherboard Assembly Number : 73-15800-08
Motherboard Serial Number : FOC20288B5M
Model Revision Number : AB0
Motherboard Revision Number : A0
Model Number : WS-C3850-48P
System Serial Number : FCW2029D1JZ
Switch Ports Model SW Version SW Image Mode
1 56 WS-C3850-48P 03.06.03E cat3k_caa-universalk9 INSTALL
2 56 WS-C3850-48P 03.06.03E cat3k_caa-universalk9 INSTALL
3 56 WS-C3850-48P 03.06.03E cat3k_caa-universalk9 INSTALL
4 56 WS-C3850-48P 03.06.03E cat3k_caa-universalk9 INSTALL
* 5 56 WS-C3850-48P 03.06.03E cat3k_caa-universalk9 INSTALL
6 56 WS-C3850-48P 03.06.03E cat3k_caa-universalk9 INSTALL
7 56 WS-C3850-48P 03.06.03E cat3k_caa-universalk9 INSTALL
Switch 01
Switch uptime : 4 weeks, 4 hours, 32 minutes
Base Ethernet MAC Address : d4:2c:44:a6:b0:00
Motherboard Serial Number : FOC20288BVT
System Serial Number : FOC2029U21G
Switch 02
Base Ethernet MAC Address : 00:87:31:0a:f3:80
Motherboard Serial Number : FOC2029A65J
System Serial Number : FCW2029C207
Switch 03
Base Ethernet MAC Address : 00:a2:89:ad:d5:00
Motherboard Serial Number : FOC2028675L
System Serial Number : FCW2029F12C
Switch 04
Base Ethernet MAC Address : 00:87:31:0a:df:00
Motherboard Serial Number : FOC202868GY
System Serial Number : FCW2029F1S5
Switch 06
Switch uptime : 4 weeks, 4 hours, 33 minutes
Base Ethernet MAC Address : 00:87:31:0a:e2:00
Motherboard Serial Number : FOC202866Y5
System Serial Number : FOC2029X1Q0
Switch 07
Switch uptime : 1 day, 18 hours, 36 minutes
Base Ethernet MAC Address : d4:2c:44:b4:0a:00
Motherboard Serial Number : FOC20288C99
System Serial Number : FCW2029C15C
Configuration register is 0x102
