Simple routing and switching problem
alexb931
Could someone please explain to me why only VLAN 1 in this set up can ping other routers and bits on different subnets and  VLAN 2 and 3 can't seem to ping anything? Also DHCP only works for VLAN 1
Switch one -
hostname SWITCH1
spanning-tree mode pvst
interface FastEthernet0/1
switchport access vlan 2
interface FastEthernet0/2
switchport access vlan 3
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
switchport mode trunk
interface GigabitEthernet0/2
interface Vlan1
ip address 192.168.1.4 255.255.255.0
interface Vlan2
ip address 192.168.2.1 255.255.255.0
interface Vlan3
ip address 192.168.4.1 255.255.255.0
line con 0
line vty 0 4
login
line vty 5 15
login
end
Now for the router -
Router#show run
Building configuration...
Current configuration : 1586 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
ip dhcp pool add
network 192.168.4.0 255.255.255.0
default-router 192.168.4.5
ip dhcp pool 2
network 192.168.2.0 255.255.255.0
default-router 192.168.2.5
ip dhcp pool 3
network 192.168.1.0 255.255.255.0
default-router 192.168.1.5
ip cef
no ipv6 cef
license udi pid CISCO2911/K9 sn FTX1524S481
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.1
encapsulation dot1Q 1 native
ip address 192.168.1.5 255.255.255.0
interface GigabitEthernet0/1.2
encapsulation dot1Q 2
ip address 192.168.2.5 255.255.255.0
interface GigabitEthernet0/1.3
encapsulation dot1Q 3
ip address 192.168.4.5 255.255.255.0
ip address 192.168.3.5 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/2.2
no ip address
interface Vlan1
no ip address
shutdown
router ospf 1
log-adjacency-changes
network 10.1.1.1 0.0.0.0 area 0
network 10.1.2.1 0.0.0.0 area 0
network 10.1.3.1 0.0.0.0 area 0
network 10.1.1.0 0.0.0.255 area 0
network 10.1.2.0 0.0.0.255 area 0
network 192.168.1.0 0.0.0.255 area 0
network 192.168.2.0 0.0.0.255 area 0
network 192.168.3.0 0.0.0.255 area 0
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
I'm using packet tracer.
Any help would be very much appreciated.
Kind regards,
Alex
P.S. This is switch 2 that has VLAN 1 working from. Both switches are running VTP successfully.
Current configuration : 1092 bytes
version 12.2
hostname Switch
interface Vlan1
no ip address
shutdown
line con 0
line vty 0 4
login
line vty 5 15
login
end
Switch#
5 Replies 5
Dennis Mink
can you give us an example of what does NOT ping and what does. and also what the respective default gateways are on the machines you are pinging from?
and can you ping the default gateways in each respective VLAN?
Please remember to rate useful posts, by clicking on the stars below.
have you enabled ip routing for intervlan routing ?
can you post show int trunk from the switches make sure everything's being allowed through
Hi Guys,
I've added a screen shot of the network.
Basically VLAN 2 and 3 can ping hosts on the same LAN but can't ping its default route or other VLANs. VLAN 1 can ping everything perfectly even the routers on the ride hand side of the network .
Port Mode Encapsulation Status Native vlan
Gig0/1 on 802.1q trunking 1
Port Vlans allowed on trunk
Gig0/1 1-1005
Port Vlans allowed and active in management domain
Gig0/1 1,2,3
Port Vlans in spanning tree forwarding state and not pruned
Gig0/1 1,2,3
SWITCH1#
Possibly the fact I can't ping the default route says a lot, but I don't know where i'm going wrong
Alex
On switch 1  you do not need SVI's configured to route anything as the router is handling that duty . Delete interface vlan 2 and 3 if you are using interface vlan 1 to manage the switch. Also keep in mind packettracer  has been known to be buggy so it's possible that could be a factor too.   Check to make sure all vlans are created on your switches by doing a sh vlan command .  Check trunks between the switches and from the switches to the router.
I've found the problem!
I had the wrong interface as the trunk, I had gig0/1 instead of 0/2! Explains why only VLAN one was working I suppose.
Thank you both for your help
Alex
