08-28-2017 06:19 AM - edited 03-08-2019 11:51 AM
Hi All,
I am stuck with an issue of SIP Trunk Between CME on 2951 and Huawei SOFTX3000
I am unable to make calls and also cannt recieve calls.
My phone rings when there is incoming call but when i pick the hand set there is no sound.
Similar is the case with my outgoing call as well
I am atatching the documets
Kinldy help me
02-22-2018 11:23 AM
hi all
I have also similar problem
anybody knows how to fix it ?
02-24-2018 11:23 PM
hi
i have similar problem with 2811 and softx3000
did you solved the problem ?
thanks
