Slow Etherchannel?
Mariusz00001
I have 2x2950s and 2x3550s trying to set up  etherchannels between them. Everything looks ok but the speed is still  around 100Mbps even though there are 2xFE trunks everywhere.
I tried to isolate it, connecting 2x2950s together - the same, I get max 100Mbps...
My basic topology:
PC with a Gb NIC -----------------2950-----------------------2950--------------PC with a Gb NIC
Iperf results:
[  4] local 172.16.1.144 port 5001 connected with 172.16.1.28 port 51554
[  4]  0.0-10.0 sec   102 MBytes  85.4 Mbits/sec
[  4] local 172.16.1.144 port 5001 connected with 172.16.1.28 port 51675
[  4]  0.0-10.0 sec   107 MBytes  89.3 Mbits/sec
I  tried to change PO ports to active/active - still the same. When I  connect these PCs to the same 2950 switch using two gigabit ports, I  get:
[  4]  0.0-10.0 sec   390 MBytes   327 Mbits/sec
I  also tried to copy from PC3 to both PC1 and PC2 at the same time to  make sure it can load balance - unfortunately I was getting 5-6MBps for  each connection only
Have I missed anything obvious???
My basic config and show commands:
SWITCH1
switch1#sh run int po1
Building configuration...
Current configuration : 207 bytes
interface Port-channel1
description ETHERCHANNEL
switchport trunk native vlan 2
switchport trunk allowed vlan 1-4,99,1002-1005
switchport mode trunk
switchport nonegotiate
flowcontrol send off
end
switch1#sh run int f0/18
Current configuration : 190 bytes
interface FastEthernet0/18
channel-group 1 mode active
end
switch1#sh run int f0/19
interface FastEthernet0/19
end
switch1#sh ethe
switch1#sh etherchannel su
switch1#sh etherchannel summary
Flags:  D - down        P - in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        u - unsuitable for bundling
        U - in use      f - failed to allocate aggregator
        d - default port
Number of channel-groups in use: 1
Number of aggregators:           1
Group  Port-channel  Protocol    Ports
1      Po1(SU)         LACP      Fa0/18(P)   Fa0/19(Pd)
switch1#sh int po1
Port-channel1 is up, line protocol is up (connected)
  Hardware is EtherChannel, address is 0009.43ae.ce13 (bia 0009.43ae.ce13)
  Description: ETHERCHANNEL
  MTU 1500 bytes, BW 200000 Kbit, DLY 1000 usec,
     reliability 255/255, txload 5/255, rxload 1/255
  Full-duplex, 100Mb/s, media type is unknown media type
  input flow-control is off, output flow-control is off
  Members in this channel: Fa0/18 Fa0/19
  Last input 00:01:23, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 89000 bits/sec, 172 packets/sec
  5 minute output rate 4495000 bits/sec, 354 packets/sec
     2831392 packets input, 2669151653 bytes, 1056 no buffer
     Received 36665 broadcasts (29399 multicast)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 1056 ignored
     0 watchdog, 29399 multicast, 0 pause input
     2885680 packets output, 3152464741 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
SWITCH2
switch2#sh run int po1
Current configuration : 206 bytes
end
switch2#sh run int f0/18
end
switch2#sh run int f0/19
end
switch2#sh ethe su
        d - default port
1      Po1(SU)         LACP      Fa0/18(Pd)  Fa0/19(P)
switch2#sh int po1
  Hardware is EtherChannel, address is 000a.b7dd.3d12 (bia 000a.b7dd.3d12)
     reliability 255/255, txload 1/255, rxload 4/255
  Last input 00:00:00, output 00:02:58, output hang never
  5 minute input rate 3268000 bits/sec, 254 packets/sec
  5 minute output rate 56000 bits/sec, 117 packets/sec
     2896053 packets input, 3157891899 bytes, 0 no buffer
     Received 33572 broadcasts (28209 multicast)
     0 watchdog, 28204 multicast, 0 pause input
     2755632 packets output, 2612593705 bytes, 0 underruns
ALIAOF_
Level 6
Level 6
Well your ports that are in the port channel are 100Meg ports so certainly you won't get more than 100Meg out of it.  When you do a port channel default load balancing method on the switch is src-mac.  Which means if PC1 has a MAC of x.x.x and it is the source all data will go over the first link.  Now if you add another PC with a MAC of y.y.y that will go over the second link.  Higher end switches offer better and more granular load balancing methods such as source and destination mac or IP, ports etc.
7 Replies 7
ALIAOF_
Level 6
Level 6
Mohammad, that is what I did:
PC1 ------------------2950-------------2950 ----------------PC2 and PC3
Was getting max 6MBps on PC2 and PC3 when sending files to PC1....
Anyone pls?
Hello
Try and recreate the port-channel-
1)Config the physical interfaces involved to default and delete the port-channel
2) assign channel-group and channel-group number on the physical interfaces
on let port-channel be created automaticlly
4)create trunking encapsulation direactly in port-channel interface config mode
5)reset physical interfaces "shut" "no shut"
your port-channel config should be copied onto the physical interfaces automatically.
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
Ok so if you were getting 6MBps that is equal to 48Mbps.  That should be fine on a 100Mbps link.  What kind of transfer was it?  Your PC's have a gigabit NICs but your switch supports 100Meg only.  So try to hard code the NIC to 100Meg and see what happens.
PC1,PC2----------2950--------------2950------------PC3,PC4
copy a file PC1->PC3
copy a file PC2->PC4
All worked great, 100Mb on both PCs.
Thx guys!
Thank you for the update, did you have to hard code the NIC settings ?
