SM-ES3-24-P on 3925 in failed state
daniel_tarbuck
I have an SM-ES3-24-P switch module that seems to be in a failed state.  How can I revive it?
#service-module gi 2/0 status
Service Module is Cisco GigabitEthernet2/0
Service Module supports session via TTY line 131
Service Module is failed
Service Module reset on error is disabled
Service Module heartbeat-reset is enabled
Service Module status is not available
Slot 2:
        SM-ES3-24-P: EtherSwitch SM L3 + PoE + 23 10/100 + 1 10/100/1000 Port adapter, 1 port
        Port adapter is analyzed
        Port adapter insertion time 03:15:33 ago
        EEPROM contents at hardware discovery:
        Hardware Revision        : 1.0
        Part Number              : 73-11857-04
        Board Revision           : B0
        Deviation Number         : 0
        Fab Version              : 04
        PCB Serial Number        : <removed>
        RMA Number               : 0-0-0-0
        RMA History              : 00
        RMA Test History         : 00
        Base MAC Address         : c84c.7500.fc80
        MAC Address block size   : 128
        Top Assy. Part Number    : 800-31024-04
        Product (FRU) Number     : SM-ES3-24-P
        Version Identifier       : V01
        CLEI Code                : COUCAJ5CAA
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF 40 06 2B 41 01 00 82 49 2E 51 04 42 42 30
          0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 34 31 37
          0x20: 32 30 34 51 81 00 00 00 00 04 00 03 00 D9 02 40
          0x30: C1 CF 06 C8 4C 75 00 FC 80 43 00 80 C0 46 03 20
          0x40: 00 79 30 04 CB 8B 53 4D 2D 45 53 33 2D 32 34 2D
          0x50: 50 89 56 30 31 20 C6 8A 43 4F 55 43 41 4A 35 43
          0x60: 41 41 F3 00 06 40 0B E3 43 00 29 FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
I can't connect to it:
#service-module gi 2/0 session
Trying 192.168.148.1, 2131 ...
% Connection refused by remote host
line 131
no activation-character
no exec
transport preferred none
transport input all
stopbits 1
flowcontrol software
 #service-module gi 2/0 password-reset
Do you want to proceed with password reset process?[confirm]
Starting password reset process...
Wait for 50 secs for password reset process to complete
And password-reset seems to never complete.
I think someone installed firmware for the SM-X-ES3 module on it.  Do I have any hope?
balaji.bandi
it says Failed :
what is the IOS Code running ?   Try turnoff the router (if possible) and reseat the module and test it.
check some guide lines :
https://www.cisco.com/c/en/us/td/docs/routers/access/interfaces/software/feature/guide/eesm_sw.html
BB
Running 15.7(3)M5 on the router.  I have reseated, reloaded, oir-stop / oir-start.  Nothing seems to work.
I have the correct firmware for the module on the router flash, I am trying to find a way to initiate Xmodem transfer, but so far I am unsuccessful.
not sure is this supported for replacement.
BB
