SNMP problem
tedauction
Level 5
Level 5
Hello, I am having trobule establishing an SNMP connection  to a 2960 switch. I am certain the community string, version and ports are correct as they are identical to dozens of other devices I have.
The results of 'sh snmp' are as per below.
Is this saying that my switch is sending SNMP responses out as per normal ?
56 SNMP packets input
0 Bad SNMP version errors
0 Unknown community name
0 Illegal operation for community name supplied
0 Encoding errors
48 Number of requested variables
0 Number of altered variables
28 Get-request PDUs
24 Get-next PDUs
0 Set-request PDUs
52 SNMP packets output
0 Too big errors (Maximum packet size 1500)
0 No such name errors
0 Bad values errors
0 General errors
52 Response PDUs
0 Trap PDUs
SNMP global trap: disabled
Brandon Buffin
Looks normal. Is there a line below that says "SNMP agent enabled"? I don't have a 2960 to test so not sure that shows up in the config. Also, check your SNMP source interface.
Brandon
Brandon Buffin
Brandon
sorry guys, it turned out to be an ACL in the path blocking traffic.
