SNMP Traps Question
Patrick McHenry
Level 7
Level 7
Hi -
I noticed on a router config under snmp traps
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps ds1
snmp-server enable traps tty
snmp-server enable traps flash insertion removal
snmp-server enable traps envmon
snmp-server enable traps ds0-busyout
snmp-server enable traps ds1-loopback
snmp-server enable traps ethernet cfm cc mep-up mep-down cross-connect loop config
snmp-server enable traps ethernet cfm crosscheck mep-missing mep-unknown service-up
snmp-server enable traps aaa_server
snmp-server enable traps bulkstat collection transfer
snmp-server enable traps memory bufferpeak
snmp-server enable traps config-copy
snmp-server enable traps config-ctid
snmp-server enable traps dsp card-status
snmp-server enable traps dsp oper-state
snmp-server enable traps entity
snmp-server enable traps fru-ctrl
snmp-server enable traps event-manager
snmp-server enable traps ospf state-change
snmp-server enable traps ospf errors
snmp-server enable traps ospf retransmit
snmp-server enable traps ospf lsa
snmp-server enable traps ospf cisco-specific state-change nssa-trans-change
snmp-server enable traps ospf cisco-specific state-change shamlink interface-old
snmp-server enable traps ospf cisco-specific state-change shamlink neighbor
snmp-server enable traps ospf cisco-specific errors
snmp-server enable traps ospf cisco-specific retransmit
snmp-server enable traps ospf cisco-specific lsa
snmp-server enable traps cpu threshold
snmp-server enable traps ipsla
snmp-server enable traps syslog
snmp-server enable traps isakmp policy add
snmp-server enable traps isakmp policy delete
snmp-server enable traps isakmp tunnel start
snmp-server enable traps isakmp tunnel stop
snmp-server enable traps ipsec cryptomap add
snmp-server enable traps ipsec cryptomap delete
snmp-server enable traps ipsec cryptomap attach
snmp-server enable traps ipsec cryptomap detach
snmp-server enable traps ipsec tunnel start
snmp-server enable traps ipsec tunnel stop
snmp-server enable traps ipsec too-many-sas
Do these traps have to configured manually or are they enabled by default?
This is a config from a 2800. Would there be different snmp traps for a 1001 router?
Thanks, Pat
Giuseppe Larosa
Hello Patrick,
I think there is an all option to enable all supported SNMP traps on device.
I guess that is the command that has been used here
The list of supported SNMP traps is platform dependent, so if you are moving to an ASR 1001 the list of traps will be similar but different in some items
Hope to help
Giuseppe
Giuseppe Larosa
Hello Patrick,
Hope to help
Giuseppe
