SNMPv3 Catalyst 6506 12.2(18)SXF14
sdawson35
                    We are unable to configure snmp v3 on the above.
                    Does anyone have a proper idiots guide for this ?
                    When adding a user there is no otion to add a "priv" level and I think this is why it doesnt work ?
                    snmp-server user ITOPS_IS NETMON v3 "(access)(auth)(encrypted)"
                    snmp-server user ITOPS_IS NETMON v3 auth sha  Thissucks! (access)
Please help, this is so damned annoying .
Scott.
mvsheik123
Level 7
Level 7
Below config worked for me (currently used).
snmp-server group TEST v3 auth read XYZ notify XYZ
snmp-server view XYZ iso included
snmp-server user USER1 TEST v3 auth sha priv aes 128
snmp-server host version 3 auth USER1
hth
MS
Thats what I have been trying but do not get the "priv" option when adding the user.
I guess you already created group. View also enabled? Not sure, if this is mandatory. Its been long time since I set this up and I remember doing some back and forth testing with settings.
Thx
MS
