Software to gather ip interfaces info
fabio.marino
Hi to all, i'm looking for a freeware software able to gather information from routers using cli command such as "show ip interface brief" or something like this and save it in txt file or log file. Thanks
Latchum Naidu
Try to see NetRouteView – Network Route Viewer for Windows
NetRouteView is a Portable Network Route Viewer for Windows. Created by NirSoft, it lists the currently active routes on your network. NetRouteView can display destination, mask, gateway, interface IP address, metric value, type, protocol, age, interface name, MAC address and more. Additional features include the ability to add new routes, and modify or delete existing routes.
See the below link for more tools...
http://www.pendriveapps.com/software/portable-network-tools/
Please rate the helpfull posts.
Naidu.
Thanks for your time and your help.
Please don't forget to rate the helpfull posts.
Naidu.
