solution for - SSH Server CBC Mode Ciphers Enabled SSH Weak MAC Algorithms Enabled
WEERAKOO69BA
Level 4
Level 4
Dear All,
Kindly can anyone tell me what is the solution for the  following .
I have seen in the forum it has mentioned the solution as
(config)# ip ssh server algorithm encryption aes128-ctr aes192-ctr aes256-ctr
(config)# ip ssh server algorithm mac hmac-sha1
And also this doesn't take in version 12 except 15.
1)Is there any way to fix the same issue on version 12?
2)if it is version 15,what is the correct version?
 My affected products are-nexus,6500,3700 etc
Pls help me to get this resolve
Thank you.
0 Replies 0
