Hi All,
I have configured the SPAN for 6500
with following command
set span 107-110,301-350 1/2
in sh run it shows below one including other parameter which i did not set:-
set span 107-110,301-350 1/2 both inpkts disable learning enable multicast enable create
but when i check the status of SPAN it shows following status :-
Destination : Port 1/2
Admin Source : VLAN 107-110,301-350
Oper Source : None
Direction : transmit/receive
Incoming Packets: disabled
Learning : enabled
Multicast : enabled
Filter : -
Status : inactive
Total local span sessions: 1
ANd the port stauts of destination is here
sh port 1/2
Port Name Status Vlan Duplex Speed Type
1/2 IDS-02 notconnect 999 full 1000 1000BaseSX
Can you please check and let me know whether there is issue with my configuration for SPAN or it is inactive because the destination port is connected?
Thanks in anticipation
Jagdev
