Span Port
sureshmv
In one of my location using catalyst2900 eriesXl switch with IOS ver 11.2.I want to make one port as span for the other port where i connect my firewall for the process of monitering the triffic.Can I do the span port on this switch if so what is the command.
rmcarthur
Hi, this link should cover it. Not sure which release it was introduced so you may have to upgrade from 11.2.
http://www.cisco.com/en/US/products/hw/switches/ps637/products_configuration_guide_chapter09186a008007e838.html#xtocid22
hth
The port monitor command was introduced in 11.2(8)SA.
http://www.cisco.com/univercd/cc/td/doc/product/lan/c2900xl/29_35wc4/cref/clicmds.htm#xtocid53
regards
-Alok
