Spanning Tree MST per Vlan, best practice
Patrick Werner
Hi Community.
I did the following MST Spanning Tree Config
spanning-tree mst configuration
  name xxxxxxx
  revision1
  instance 1 vlan 1, 10-20, 25, 30
So I added every Vlan to the config which we use. But every time when I add one more vlan to the config the whole network get a little outage.
I see lots of MAC Flaps on ports with two Server links and the outage is for some seconds.
Is it a better practice to add all possible Vlans to the config. So I do the config like that:
  instance 1 vlan 1-4096
What you think.
Best Regards patrick
Reza Sharifi
Correct, that is normal behavior with MST.
I would just add "instance 1 vlan 1-4094" this way there is no outage when you bring up a new vlan.
