Spanning Tree - Problems
kooper390
Community Member
Hi all!
I tried to deploy a network infrastucture with 6 switches (different vendors).
The Problem seems to be, that I have 2 root bridges. Ok I think one switch dont forward the BPDU, so two trees are established.
SW01 --- SW03 --- SW05 --- SW06
SW02 --- SW04
Tree 1: SW01 to SW04
Tree 2: SW05 to SW06
The only default value I changed, was the bridge prio for SW03 to 4096. There is no BPDU or root bridge guard enabled.
If I make a new connection from SW05 to SW04 the storm beginns.
Some Ideas for troubelshooting?
Gerit
IAN WHITMORE
Level 9
Level 9
What make/model are your switches?
What STP protocol is running on each of them? And priority of each?
Regards.
cadet alain
It's impossible, you can only have one root bridge per VLAN( PVST+,RPVST+) or for multiple VLANs( MST).
The only part where there could be a loop is  the left part unless if you have redundant links not bonded between sw5 and sw6.
Then STP is not doing its job.  Could you post output of following commands:
-sh span vlan X on sw3 where X is the vlan used for the connection
-sh int x/x switchport where x/x is interface on sw3 to sw 5
-sh int trunk on sw3
Regards.
Alain.
right! OK, it seems  that SW05 and SW03 don't speak to each other.
But I can ping in the entire network.
SW05 is a Brocade FLS648 and SW05 is a Intel SBCEGBESW1 (Blade Center).
SW03 have 4096 a prio.
And I hope I have everywhere turn RSTP on.
STP work for SW01 to SW04 and SW05 to SW06
Gerit
just post the commands I asked please.
How do you know there is a storm? How do you detect it?
Regards.
Alain.
