srw224g4p making loud noise - need to open it up
chrobi2012
are there any manuals on how to open the srw224g4p switch? I can't find anything
the switch is making a lot of noise - sound like the fan
jimmysands73_2
Level 5
Level 5
Whatever you do, dont search google
http://www.ita.wat.edu.pl/~zswier/SK/LAB%203/linksys-SRW224G4P-manual.pdf
I quickly scanned it, I dont see opening instructions.  But can not be that hard (famous last words!).  Careful, sometimes breaking seals can void warrenties, if its still on one.
Message was edited by: Jimmy Sands From Ciscos site: http://www.cisco.com/en/US/docs/switches/lan/csbms/srw2048/administration/guide/SRW-US_v10_UG_A-Web.pdf
thanks, I also found that manual yesterday but as you said, it doesn't say anything about opening it up ;/
