SSH 9200 issue
milton-santos
Frequent Visitor
Frequent Visitor
I have a cisco catalyst 9200 and I'm trying to access the equipment via ssh but it's not possible, it has an error stating that access was denied, but access via http is possible without any problem.
milton-santos
Frequent Visitor
Frequent Visitor
Hello, dear my friends.
I managed to solve the access problem.
I did configuration like @MHM Cisco World explaned about of authentication, but after this don't worked yet, so I configurated one interface port-channel, interface vlan 250 for Management my device and passed that vlan into trunk between device direct connect.
Because before this I mas tryied connect in my switch by vlan 1 default.
So my configation now in switch
ersion 17.12
platform punt-keepalive disable-kernel-core
hostname SWCORESPDC01
vrf definition Mgmt-vrf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
aaa new-model
aaa authentication login default local
aaa session-id common
switch 1 provision c9200l-48p-4g
ip domain name suel.2017
ip dhcp pool webuidhcp
login on-success log
vtp version 1
crypto pki trustpoint SLA-TrustPoint
 enrollment pkcs12
 revocation-check crl
 hash sha256
crypto pki trustpoint TP-self-signed-284757285
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-284757285
 revocation-check none
 rsakeypair TP-self-signed-284757285
 hash sha256
crypto pki certificate chain SLA-TrustPoint
 certificate ca 01
  quit
crypto pki certificate chain TP-self-signed-284757285
 certificate self-signed 01
  quit
license boot level network-essentials addon dna-essentials
memory free low-watermark processor 8237
diagnostic bootup level minimal
spanning-tree mode rapid-pvst
enable secret 9 $9$Om0uz4cfTCO11.$ogHFR3Zplntw0jBp1UvEmjzWZclfpF0KbeWp3jK06wM
username milton privilege 15 secret 9 $9$rjFUTaA5n1w5dk$jfwsNTNVx/EZrbmj73FofZF1tkjw6FAP9qXyrMlA1u6
redundancy
 mode sso
crypto engine compliance shield disable
transceiver type all
 monitoring
lldp run
interface Port-channel1
 switchport trunk allowed vlan 1,250
 switchport mode trunk
 switchport nonegotiate
interface GigabitEthernet0/0
 vrf forwarding Mgmt-vrf
 no ip address
interface GigabitEthernet1/0/48
 channel-group 1 mode active
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface Vlan1
 ip dhcp client client-id ascii cisco-20db.eada.8dc7-Vl1
 ip address dhcp
interface Vlan250
 ip address 10.10.250.252 255.255.255.0
ip http server
ip http secure-server
ip http client source-interface Vlan1
ip forward-protocol nd
ip ssh bulk-mode 131072
control-plane
 service-policy input system-cpp-policy
line con 0
 exec-timeout 0 0
 stopbits 1
line vty 0 4
 privilege level 15
 transport input ssh
line vty 5 15
 privilege level 15
 transport input ssh
end
14 Replies 14
Did you configure the following:
Hostname
Router(config)#hostname <host name>
Domain name
ip domain-name <Domain Name>
Generate the SSH key
Router(config)#crypto key generate rsa modulus <size>
Enable SSH transport
SWITCH(config)#ip ssh version 2
Make sure under the VTY lines you allow the SSHE transport
line vty 0 4
transport input ssh
If so, please provide us the configuration to further assist along with any error messages you are getting and how you are trying to access the device.
-David
Hi, David. I did this but doesn't work.
Building configuration...
Current configuration : 13053 bytes
! Last configuration change at 04:04:52 UTC Wed Jul 9 2025 by joao.sino
version 17.12
hostname SWCORESPDCSUEL02
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
logging console emergencies
aaa new-model
line vty 0 4
privilege level 15
length 0
transport input ssh
line vty 5 15
privilege level 15
transport input ssh
Hello @milton-santos
if you have followed Mr Ruess advices and it is not OK after that, please check you logs...
Thanks for sharing your logs output.
Also, do you configured a local username with privileges associated ? If yes you need the command login local under line vty 0 4.
Best regards
Is the same device you using for GUI access  for SSH, what SSH client you using ?  ( if not far way the switch, suggest to console to see the Logs - that give you clear direction what is wrong) - you can also view the Logs on Gui when you trying to access SSH.
#show ip ssh  (from console try) or from GUI command execution try and post the output.
I use  always quick fix for the switches have SSH issue as below - change the username and password as per requirement.
enable secret 5 $1$jtK0$yyHFcVM7xyelts1csVwrV/
username cisco privilege 15 secret 5 $1$0qFD$ZEMDi.7z1QTtF4EuPdlSY.
aaa new-model
clock timezone GMT 0 0
clock summer-time BST recurring last Sun Mar 1:00 last Sun Oct 2:00
no ip domain-lookup
ip domain-name bb.com
ip cef
no ipv6 cef
ip ssh version 2
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous level 0 limit 20
stopbits 1
line aux 0
line vty 0 4
privilege level 15
password cisco
transport input ssh
transport output all
######### Generate SSH keys :
BB
Friend
Never NEVER add
Aaa new-model
Before you add
1- username password privilege 15
2- enable password
And after you add aaa new-model
You need
Aaa authentication login defualt local
Aaa authorization defualt local
Here your vty use aaa becuase you add aaa new-model
Be careful abd dont WR config before you sure you can access vty (telent and ssh) and console
MHM
Dear my friends,
I made that the output commands don't work. just below is a configuration without a switch.
milton-santos
Frequent Visitor
Frequent Visitor
Dear my friends. @MHM Cisco World @balaji.bandi M02@rt37 @David Ruess
I already made these configs and even so it is still not possible to access via ssh. Below are the configs made on the switch, and I removed some things so that the output would not be too big.
# sh run
Current configuration : 13139 bytes
! Last configuration change at 00:20:17 UTC Thu Jul 10 2025 by milton.itowl
version 17.12
hostname SWCORESPDC02
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
aaa new-model
aaa local authentication default authorization default
aaa authentication login defualt local
boot system switch all flash:packages.conf
ip domain name mydomain.local
vtp version 1
enrollment pkcs12
hash sha256
crypto pki trustpoint TP-self-signed-3259926389
subject-name cn=IOS-Self-Signed-Certificate-3259926389
rsakeypair TP-self-signed-3259926389
hash sha256
certificate ca 01
quit
crypto pki certificate chain TP-self-signed-3259926389
certificate self-signed 03
quit
enable secret 9 $9$su1ecJc3i5eBGE$sC.IpqPOYaW5XXevGUIW9cWVCeA60oZXPh2QzOCRTSw
enable password cisco@1234
username cisco privilege 15 password 0 cisco
redundancy
mode sso
monitoring
lldp run
class-map match-any system-cpp-police-ewlc-control
description EWLC Control
class-map match-any system-cpp-police-topology-control
description Topology control
class-map match-any system-cpp-police-sw-forward
description Sw forwarding, L2 LVX data packets, LOGGING, Transit Traffic
class-map match-any system-cpp-default
description EWLC data, Inter FED Traffic
class-map match-any system-cpp-police-sys-data
description Openflow, Exception, EGR Exception, NFL Sampled Data, RPF Failed
class-map match-any system-cpp-police-punt-webauth
description Punt Webauth
class-map match-any system-cpp-police-l2lvx-control
description L2 LVX control packets
class-map match-any system-cpp-police-forus
description Forus Address resolution and Forus traffic
class-map match-any system-cpp-police-multicast-end-station
description MCAST END STATION
class-map match-any system-cpp-police-high-rate-app
description High Rate Applications
description MCAST Data
class-map match-any system-cpp-police-l2-control
description L2 control
class-map match-any system-cpp-police-dot1x-auth
description DOT1X Auth
class-map match-any system-cpp-police-data
description ICMP redirect, ICMP_GEN and BROADCAST
class-map match-any system-cpp-police-stackwise-virt-control
description Stackwise Virtual OOB
class-map match-any non-client-nrt-class
class-map match-any system-cpp-police-routing-control
description Routing control and Low Latency
class-map match-any system-cpp-police-protocol-snooping
description Protocol snooping
class-map match-any system-cpp-police-dhcp-snooping
description DHCP snooping
class-map match-any system-cpp-police-ios-routing
description L2 control, Topology control, Routing control, Low Latency
class-map match-any system-cpp-police-system-critical
description System Critical and Gold Pkt
class-map match-any system-cpp-police-ios-feature
description ICMPGEN,BROADCAST,ICMP,L2LVXCntrl,ProtoSnoop,PuntWebauth,MCASTData,Transit,DOT1XAuth,Swfwd,LOGGING,L2LVXData,ForusTraffic,ForusARP,McastEndStn,Openflow,Exception,EGRExcption,NflSampled,RpfFailed
policy-map system-cpp-policy
no ip address
interface Vlan1
ip dhcp client client-id ascii TSP28470068
ip address dhcp
interface Vlan250
ip address 10.10.250.250 255.255.255.0
ip default-gateway 192.168.6.1
ip http server
ip http authentication local
ip ssh maxstartups 2
ip ssh time-out 60
control-plane
line con 0
exec-timeout 0 0
stopbits 1
line vty 0 4
privilege level 15
password cisco
length 0
transport input ssh
line vty 5 15
privilege level 15
password cisco
transport input ssh
end
Did you add the following command:
If so can you run a debug of ssh and show us any log/errors when you try to log into the device please?
-David
-> typo error ?
Check that please.
Best regards
Let me ask you some basic Questions here :
1. what is IP address from you are connecting to the device ?
2. This switch acting as Layer2,  what is the IP address you get for VLAN 1 from DHCP ?
3. can you post show ip ssh (it was asked before)
4.  do you need to VTP on this switch, if not disable by doing vtp mode transparent (this will become server, if any switch participate in VTP will be other issues)
If you need further assistance post below output :
1. show ip interface brief
2. show ip ssh (asked above)
3. show ip route
4. from what IP client you connecting ?
5. what is the terminal client you using to connect to SSH.
here is my test Lab cat 9K config
version 17.12
! Call-home is enabled by Smart-Licensing.
service call-home
hostname BBTEST
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
aaa new-model
ip domain name bb.com
 enrollment pkcs12
crypto pki trustpoint TP-self-signed-2874884994
 subject-name cn=IOS-Self-Signed-Certificate-2874884994
 rsakeypair TP-self-signed-2874884994
 certificate ca 01
  30820321 30820209 A0030201 02020101 300D0609 2A864886 F70D0101 0B050030
  32310E30 0C060355 040A1305 43697363 6F312030 1E060355 04031317 43697363
  6F204C69 63656E73 696E6720 526F6F74 20434130 1E170D31 33303533 30313934
  3834375A 170D3338 30353330 31393438 34375A30 32310E30 0C060355 040A1305
  43697363 6F312030 1E060355 04031317 43697363 6F204C69 63656E73 696E6720
  526F6F74 20434130 82012230 0D06092A 864886F7 0D010101 05000382 010F0030
  82010A02 82010100 A6BCBD96 131E05F7 145EA72C 2CD686E6 17222EA1 F1EFF64D
  CBB4C798 212AA147 C655D8D7 9471380D 8711441E 1AAF071A 9CAE6388 8A38E520
  1C394D78 462EF239 C659F715 B98C0A59 5BBB5CBD 0CFEBEA3 700A8BF7 D8F256EE
  4AA4E80D DB6FD1C9 60B1FD18 FFC69C96 6FA68957 A2617DE7 104FDC5F EA2956AC
  7390A3EB 2B5436AD C847A2C5 DAB553EB 69A9A535 58E9F3E3 C0BD23CF 58BD7188
  68E69491 20F320E7 948E71D7 AE3BCC84 F10684C7 4BC8E00F 539BA42B 42C68BB7
  C7479096 B4CB2D62 EA2F505D C7B062A4 6811D95B E8250FC4 5D5D5FB8 8F27D191
  C55F0D76 61F9A4CD 3D992327 A8BB03BD 4E6D7069 7CBADF8B DF5F4368 95135E44
  DFC7C6CF 04DD7FD1 02030100 01A34230 40300E06 03551D0F 0101FF04 04030201
  06300F06 03551D13 0101FF04 05300301 01FF301D 0603551D 0E041604 1449DC85
  4B3D31E5 1B3E6A17 606AF333 3D3B4C73 E8300D06 092A8648 86F70D01 010B0500
  03820101 00507F24 D3932A66 86025D9F E838AE5C 6D4DF6B0 49631C78 240DA905
  604EDCDE FF4FED2B 77FC460E CD636FDB DD44681E 3A5673AB 9093D3B1 6C9E3D8B
  D98987BF E40CBD9E 1AECA0C2 2189BB5C 8FA85686 CD98B646 5575B146 8DFC66A8
  467A3DF4 4D565700 6ADF0F0D CF835015 3C04FF7C 21E878AC 11BA9CD2 55A9232C
  7CA7B7E6 C1AF74F6 152E99B7 B1FCF9BB E973DE7F 5BDDEB86 C71E3B49 1765308B
  5FB0DA06 B92AFE7F 494E8A9E 07B85737 F3A58BE1 1A48A229 C37C1E69 39F08678
  80DDCD16 D6BACECA EEBC7CF9 8428787B 35202CDC 60E4616A B623CDBD 230E3AFB
  418616A9 4093E049 4D10AB75 27E86F73 932E35B5 8862FDAE 0275156F 719BB2F0
  D697DF7F 28
        quit
crypto pki certificate chain TP-self-signed-2874884994
  30820330 30820218 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32383734 38383439 3934301E 170D3235 30373130 30373037
  34355A17 0D333530 37313030 37303734 355A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 38373438
  38343939 34308201 22300D06 092A8648 86F70D01 01010500 0382010F 00308201
  0A028201 0100B54C 5D692133 6E3197E2 5B6F6CD5 05EB8A00 E415D12D DC8F62A1
  C6F62F19 EC26A443 A49D92B7 E5CE7DF1 4EE189B2 8F4A707D A6AD33AC 957B2E0A
  D4F27244 08672666 567433C2 2F1FC7C8 D71A3552 16920504 AFA73779 C3BC2FF6
  2CE06A7D 684723D0 5C3704BD 50E57865 DF5D64D1 75FD85C0 9E364E9D 52E155D6
  4753690A 61029F38 A0A98D5A 41526A2F D688CF2B 9F3E33D6 18F5551C E507E9A4
  175CD80F CB91D704 88344BEC C5775F53 8892019E CE1EF3A7 D38E0C1D 482C4AE6
  A1AF76D9 6FD33CBD 6AE79EFA AFAED480 5C99C3BD FE65CAB0 923EED4A 21F2A68B
  7F3F1837 2DB15D0A 63829F1B 8B01DE48 086F9C7B 54E6E069 B554F2FC C4737792
  88F13056 7B210203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF
  301F0603 551D2304 18301680 14CAA2E8 7EB364BA 73B8FC90 31CE1149 0E6E19B5
  8C301D06 03551D0E 04160414 CAA2E87E B364BA73 B8FC9031 CE11490E 6E19B58C
  300D0609 2A864886 F70D0101 05050003 82010100 0EFF3B9A D7F4857F 352B2939
  BFD4FFD0 2141A0F4 B9BD5C9A 09ADA383 D3EFB843 D4AF350A D2EE5D49 E5F8C4CA
  537AA009 5AB21F24 3DA58D1A 376D9C2E 13331580 40ED65E6 97924385 4394CBA6
  FFCD7BDD 26D357D4 906792A1 1EBE7ED5 3BDC1D69 F7A3A892 17F7AE54 410AC896
  62F55704 FD7CBD59 56201A93 60566376 27A5EAA0 786701B1 41EE67C5 F48F3D1E
  D8FF73A4 AC0BD542 EA74E991 468635F0 10BD6A81 64B63607 9E3D10A1 4629546A
  282C9D14 49D94183 FDBA956F 7508C733 E461C38A 160B3DA5 0ED15603 DE5AFF93
  7A85A5CA EB30094B A192D890 5A79ED31 591E89CE F5D20722 DC0FA23E FD964423
  8FA17C46 392832EF 82373191 569C77E5 F87F4562
        quit
memory free low-watermark processor 75927
enable secret 9 $14$jtK0$VLVqIHFV5.Ri2U$XvRZ3GquU09XimISYZtdq9qc6VSdhtgZUydk6imQDa6
username cisco privilege 15 secret 9 $14$0qFD$L6Yof9W.fyjfPE$nxc/Gpn11l/fuPOHABP8h2s//UArNmP4XFMthH4HYjc
redundancy
 mode sso
  description Sw forwarding, L2 LVX data, LOGGING
  description EWLC control, EWLC data, Inter FED
  description Learning cache ovfl, High Rate App, Exception, EGR Exception, NFL SAMPLED DATA, RPF Failed
  description Transit Traffic and MCAST Data
 ip dhcp client client-id ascii xxxxxxxxxxxxxxxx
 ip address dhcp
 negotiation auto
interface Vlan1
 no ip address
 shutdown
ip tcp mss 1280
ip tcp window-size 212000
ip http server
ip http client source-interface GigabitEthernet0/0
ip tftp source-interface GigabitEthernet0/0
control-plane
line con 0
 exec-timeout 0 0
 privilege level 15
 stopbits 1
line vty 0 4
 privilege level 15
 password cisco
 transport input ssh
line vty 5 15
 transport input ssh
call-home
 ! If contact email address in call-home is configured as [email protected]
 ! the email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications.
 contact-email-addr [email protected]
 profile "CiscoTAC-1"
  active
  destination transport-method http
end
BB
milton-santos
Frequent Visitor
Frequent Visitor
@David Ruess and M02@rt37
After apply Commands of debug ip ssh, don't show me anything, but after apply "debug ip icmp" show logs for me about of icmp.
Could be problem this model equipament ?
I try Access another equipment through the cisco and he showed these logs
*Jul 10 05:22:12.004: SSH CLIENT0: protocol version id is - SSH-2.0-OpenSSH_8.0
*Jul 10 05:22:12.004: SSH CLIENT0: sent protocol version id SSH-2.0-Cisco-1.25
*Jul 10 05:22:12.005: SSH CLIENT0: protocol version exchange successful
*Jul 10 05:22:12.005: SSH2 CLIENT 0: kexinit sent: kex algo = curve25519-sha256,[email protected],ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group14-sha256,diffie-hellman-group16-sha512
*Jul 10 05:22:12.005: SSH2 CLIENT 0: kexinit sent: encryption algo = [email protected],[email protected],[email protected],aes128-gcm,aes256-gcm,aes128-ctr,aes192-ctr,aes256-ctr
*Jul 10 05:22:12.005: SSH2 CLIENT 0: kexinit sent: mac algo = [email protected],[email protected]
*Jul 10 05:22:12.005: SSH2 CLIENT 0: send:packet of length 736 (length also includes padlen of 11)
*Jul 10 05:22:12.006: SSH2 CLIENT 0: SSH2_MSG_KEXINIT sent
*Jul 10 05:22:12.007: SSH2 CLIENT 0: ssh_receive: 1080 bytes received
*Jul 10 05:22:12.007: SSH2 CLIENT 0: input: total packet length of 1080 bytes
*Jul 10 05:22:12.008: SSH2 CLIENT 0: partial packet length(block_size)8 bytes,
needed 1072 bytes, maclen 0
*Jul 10 05:22:12.008: SSH2 CLIENT 0: input: padlength 8 bytes
*Jul 10 05:22:12.008: SSH2 CLIENT 0: SSH2_MSG_KEXINIT received
*Jul 10 05:22:12.008: SSH2 CLIENT 0: kex: server->client enc:[email protected] mac:None
*Jul 10 05:22:12.008: SSH2 CLIENT 0: kex: client->server enc:[email protected] mac:None
*Jul 10 05:22:12.008: SSH2 CLIENT 0: Using hostkey algo = ecdsa-sha2-nistp256
*Jul 10 05:22:12.008: SSH2 CLIENT 0: Using kex_algo = curve25519-sha256
*Jul 10 05:22:12.044: SSH2 CLIENT 0: sending SSH2_MSG_KEX_ECDH_INIT
*Jul 10 05:22:12.044: SSH2 CLIENT 0: send:packet of length 48 (length also includes padlen of 6)
*Jul 10 05:22:12.044: SSH2 CLIENT 0: expecting SSH2_MSG_KEX_ECDH_INIT
*Jul 10 05:22:12.049: SSH2 CLIENT 0: ssh_receive: 280 bytes received
*Jul 10 05:22:12.049: SSH2 CLIENT 0: input: total packet length of 264 bytes
*Jul 10 05:22:12.049: SSH2 CLIENT 0: partial packet length(block_size)8 bytes,
needed 256 bytes, maclen 0
*Jul 10 05:22:12.049: SSH2 CLIENT 0: input: padlength 11 bytes
*Jul 10 05:22:12.085: SSH2 CLIENT 0: kex_c25519_client: Computated digest len 32
*Jul 10 05:22:12.085: SSH2 CLIENT 0: kex_c25519_client: keytype from keyblob 2
*Jul 10 05:22:12.085: SSH2 CLIENT 0: ssh2_blob_to_key: Got blob_public key ecdsa-sha2-nistp256, blob_key_type 2, publickey_algo_type 2
*Jul 10 05:22:12.085: SSH2 CLIENT 0: ssh2_blob_to_key: curveName nistp256 with len
*Jul 10 05:22:12.085: ssh2_calculate_modulus_length: modulus len 32
*Jul 10 05:22:12.094: SSH: Signature verification successful
*Jul 10 05:22:12.094: SSH2: kex_derive_keys complete
*Jul 10 05:22:12.094: SSH2 CLIENT 0: send:packet of length 16 (length also includes padlen of 10)
*Jul 10 05:22:12.094: SSH2 CLIENT 0: newkeys: mode 1
*Jul 10 05:22:12.094: SSH2 CLIENT 0: SSH2_MSG_NEWKEYS sent
*Jul 10 05:22:12.095: SSH2 CLIENT 0: waiting for SSH2_MSG_NEWKEYS
*Jul 10 05:22:12.095: SSH2 CLIENT 0: input: total packet length of 16 bytes
*Jul 10 05:22:12.095: SSH2 CLIENT 0: partial packet length(block_size)8 bytes,
needed 8 bytes, maclen 0
*Jul 10 05:22:12.095: SSH2 CLIENT 0: input: padlength 10 bytes
*Jul 10 05:22:12.095: SSH2 CLIENT 0: newkeys: mode 0
*Jul 10 05:22:12.095: SSH2 CLIENT 0: SSH2_MSG_NEWKEYS received
*Jul 10 05:22:12.095: SSH CLIENT0: key exchange successful and encryption on
*Jul 10 05:22:12.095: SSH2 CLIENT 0: send:packet of length 28 (length also includes padlen of 6)
*Jul 10 05:22:12.096: SSH2 CLIENT 0: ssh_receive: 44 bytes received
*Jul 10 05:22:12.097: SSH2 CLIENT 0: input: total packet length of 28 bytes
*Jul 10 05:22:12.097: SSH2 CLIENT 0: partial packet length(block_size)8 bytes,
needed 24 bytes, maclen 0
*Jul 10 05:22:12.097: SSH2 CLIENT 0: input: padlength 6 bytes
*Jul 10 05:22:12.097: SSH2 CLIENT 0: send:packet of length 52 (length also includes padlen of 4)
*Jul 10 05:22:12.107: SSH2 CLIENT 0: ssh_receive: 84 bytes received
*Jul 10 05:22:12.107: SSH2 CLIENT 0: input: total packet length of 68 bytes
*Jul 10 05:22:12.107: SSH2 CLIENT 0: partial packet length(block_size)8 bytes,
needed 64 bytes, maclen 0
*Jul 10 05:22:12.107: SSH2 CLIENT 0: input: padlength 10 bytes
*Jul 10 05:22:12.107: SSH2 CLIENT 0: using method password authentication
*Jul 10 05:22:27.093: SSH2 CLIENT 0: send:packet of length 76 (length also includes padlen of 6)
and password is correct because is my firewall and I'm using my password
Debug ip ssh
Debug ip tcp transcript
Debug authen event
Share these debug please
Abd last code yoh use
MHM
milton-santos
Frequent Visitor
Frequent Visitor
ersion 17.12
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
aaa new-model
vtp version 1
 enrollment pkcs12
 hash sha256
 hash sha256
 certificate ca 01
  quit
  quit
redundancy
 mode sso
 monitoring
lldp run
 no ip address
interface Vlan1
 ip address dhcp
interface Vlan250
ip http server
control-plane
line con 0
 exec-timeout 0 0
 stopbits 1
line vty 0 4
 privilege level 15
 transport input ssh
line vty 5 15
 privilege level 15
 transport input ssh
end
Happy ending
Have a nice day
MHM
