SSH Login not working.... HELP! (I'm probably being dumb)
CPynch
Hey all, I seem to be having a 'dumb' moment. A colleague configured a 2960X and didn't setup SSH on it.
I thought I did all the necessary steps, but I seem to be getting a login prompt I can't get past.
Building configuration...
Current configuration : 2722 bytes
! Last configuration change at 14:23:37 UTC Mon Aug 1 2022
! NVRAM config last updated at 14:13:36 UTC Mon Aug 1 2022
version 15.2
no service pad
hostname REDACTED
boot-start-marker
boot-end-marker
username cisco password 0 cisco
no aaa new-model
switch 1 provision ws-c2960x-24ts-l
no ip domain-lookup
ip domain-name REDACTED.com
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface Vlan1
ip address 192.168.0.19 255.255.255.0
ip default-gateway 192.168.0.1
ip http server
ip http secure-server
ip ssh version 2
line con 0
line vty 0 4
privilege level 15
password XXXXXX
login local
transport input ssh
line vty 5 15
privilege level 15
password XXXXXX
login local
transport input ssh
end
15 Replies 15
do fresh start but check if the SW/R have public key, if have delete it (notice delete the Public Key for only ssh not other public key),
if you have only 1 % that this will effect other service then
only add new public key (generate new key) and check.
PLEASE NOTIC the PUBLIC KEY IF YOU USE FOR OTHER PROTOCOL, DELELTE IT MAKE BIG ISSUE.
BE CAREFULL FREIND.
