SSH Login problem
habeeb_talal
I configured SSH in one of cisco ASA, but i cannot login to it, i made a mistake and didn't configure telnet so i cannot access it, i configured it to authenticate with cisco ACS and i'm sure that the configration is right cuz i did it before in 2 other ASAs, so is there any solution for that.
Talal Habeeb
Amit Singh
Talal,
Did you save the config after configuring the AAA. If not, then you can reload the ASA box and it will come on the default config.
If you have saved the config then you have to do a password recovery. Please follow the link below:
http://www.cisco.com/en/US/docs/security/asa/asa71/configuration/guide/trouble.html#wp1058131
HTH,Please rate if it does.
-amit singh
Talal
You describe a problem accessing with SSH and that you did not configure telnet access. Before you get into password recovery there might be a couple of options to consider:
- is it possible to access through the console? If so you might be able to correct the configuration.
- is it possible to access through a web browser? The ASDM could allow you to correct the configuration.
Rick
Rick
Thank you all, i successfully access it through console and solve this issue.
Talal
I am glad that my suggestion was able to guide your to the solution and that you have solved your problem.
Rick
Rick
